Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Audio Equipment Discussion
Old 01-20-2018, 11:36 AM   #1
seve91
City & State: AN
My Country: Italy
Default Old Lenco R600 Stereo
Hi everyone,
got this old lenco R600 Stereo Receiver. It has worked good for all these years. Last 31st December i used it for a few hours to listen to the music.
Was working good, except for the central pot that adjust the volume and balance, if i move it i can hear some sparkling sounds, maybe the component is old and need to be replaced. Tried contacts cleaner, better but not perfect.
Anyway the day after i tried to power it on but no output sound.
It has 2 outputs: Speaker A and B, each one for 2 speakers L-R.
Usually when i select Speaker A or B i can hear the relay that powers on, this time no sound at all.
So i've disassembled it, and i've found out a very strange thing.
One pin of the coil of the relays is soldered to -40V line (tested, -40V constant).
The other pin of each coil is enabled by the control in the front of the receiver (speaker A, Speaker B).
When i power on the receiver, and i enable Speaker A for example, i have only 8VDC between the pins of the coil (same thing for Speaker B anyway), but the relay is a 24VDC one.
If i wait some time (1 min more or less) the voltage slowly increasing, and when it reaches 14V the relay powers on and all is working perfectly (both speaker A and B).
If i disconnect the power, i wait several minutes and i try again, i have to wait another minute to have the relays ON.
If i disconnect the power but i power it on again after 20 sec for example, all is working good, i suppose because the capacitor remains charged.
Looks like a capacitor problem...i replaced the ones on the left of the mainboard without success.
I didn't replace the 2 big capacitors, but i suppose their only purpose is to filter the AC power.
I don't know what to do, because i can't even find a schematic.
Maybe is due to a bad transistor? Please help, thanks
seve91 is offline   Reply With Quote
Old 01-20-2018, 02:22 PM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Old Lenco R600 Stereo
If the supply voltage is constant then the problem is on the switch end, could be corroded switch contacts, try working the switch back and forth a few times, or use a spray cleaner like deoxit.
Check the other end of the switch, or does the switch control a transistor? without a schematic I'm only guessing
R_J is offline   Reply With Quote
Old 01-20-2018, 05:57 PM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Check the +14V line on the regulator board. Here is a service manual for a similar unit:
https://elektrotanya.com/lenco_t-600.../download.html
you have to wait a little bit until the download button comes up.
Old 01-20-2018, 08:15 PM   #4
R_J
City & State: ☻
My Country: Canada
Download the manual for the A-600, it is closer (has the A & B speaker switches) https://elektrotanya.com/lenco_a-600.../download.html
If this circuit in this schematic matches the receiver:
The relay coil connect to the -37 volts then to one side of the coil, the other side of the coil connect to a 330 ohm resistor, then to the speaker switch, then to Q133 collector, which when turned on completes the circuit to ground.
Check the cap C108 on the -6.6 volt line and C120 on the -2.62 volt line
and maybe c119 off base of Q134.
Q134 is the protection circuit, so you may want to check that the voltage on L101 & L102 is close to 0 volts
If there is too much offset Q133 will not be turned on
Old 01-21-2018, 01:18 PM   #5
seve91
City & State: AN
My Country: Italy
thank you all for the answers.
I've already replaced some caps, also C119 and C120.
The only one i didn't replace was the C108....it's a 47uF capacitor.
Desoldered, is measuring 25pf...replaced and all is working now!
Thank you!
To make it perfect now, would be great if i can find a replacement for the volume/balance pot, but i've never seen a similar pot in my life.
Old 01-21-2018, 04:21 PM   #6
R_J
City & State: ☻
My Country: Canada
Good to here you have it working, Try using a good control cleaner like deoxit. you need a cleaner that leaves a bit of lube behind.
Old 01-22-2018, 12:33 AM   #7
seve91
City & State: AN
My Country: Italy
I used this one, almost everywhere on the board and on the controls.
http://www.duecielectronic.it/index2...22&cat=pulizia
I will try deoxit, but there are many different versions....which type should i buy? thank you.
Old 01-22-2018, 11:24 AM   #8
R_J
City & State: ☻
My Country: Canada
What you used is a degreaser "It rapidly evaporates, leaving no residue" I bet the control worked better shortly after spraying but the scratchy noise came back shortly after. Deoxit D series D5, just get the smallest amount, you don't need much, a small squirt into each control is all you need.
There are other brands also like MG NU-TROL, it also works, maybe just not as good, depends on who you ask and I'm not asking
Old 01-22-2018, 02:19 PM   #9
seve91
City & State: AN
My Country: Italy
buying it from Italy is quite expensive. If is that good as you said, i'll buy it.
Otherwise if you can advice me a "local" alternative products would be better.
thanks
EDIT: Bought from the US...almost 29 euros.
Old 01-22-2018, 02:57 PM   #10
R_J
City & State: ☻
My Country: Canada
I know it's not cheap, MG Chemical makes Nu-TROL which is cheaper, I just don't know what's available in Italy.
Maybe this? Kontakt Chemie Cleaner 601
https://www.thomann.de/gb/kontakt_ch...ntaktspray.htm
Old 01-23-2018, 03:34 PM   #11
seve91
City & State: AN
My Country: Italy
looks like that all these contact cleaners evaporate without residue.
Anyway i've bought it from US, i hope to fix the issue because it's impossible to find the replacement for the volume/balance pot
Old 01-23-2018, 05:59 PM   #12
R_J
City & State: ☻
My Country: Canada
Even the best control cleaners may not clear up all the scratchy sound, I have had a couple controls that were that way, I applied a small amount of contact grease into them and that fixed them.
I have seen others use a bit of white lithium grease also. DO NOT use WD-40
Old 01-25-2018, 12:48 AM   #13
seve91
City & State: AN
My Country: Italy
which contact grease do you advice? I was thinking about WD40
Why is not suggested?
Old 01-25-2018, 09:41 AM   #14
R_J
City & State: ☻
My Country: Canada
The contact grease I have is ment for electrical contacts, It came from Sony for use in there mode switches. I also have some that was used in the days of mechanical channel tuners in tv's. WD-40 could cause problems with the resitive carbon in the control.
They do make contact grease for use in automotive (to waterproof plug connections)
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
