Yamaha CR-640 LED mod, an filter cap source
    does anybody know where i can get 12,000uf 50v caps for this thing?
    also, how would you do an LED mod to the dial lamps? IIRC the voltage on the bulbs is 14v.
    Follow the white rabbit.
    Re: Yamaha CR-640 LED mod, an filter cap source
    so what size is the cap?
    as for the led, just calculate the correct resistor size.
    http://led.linear1.org/1led.wiz
      You can buy capacitors from online stores like digikey.com , newark.com , mouser.com - all three in us.
      That capacitor is for bulk storage of energy, it doesn't have to be exactly 12000 uF, you can go just a bit lower with let's say 10000uF or you can go a bit higher. Lower capacitance could affect the amplifier at extremes, let's say when you turn the volume knob way high, but that's about all.
      The voltage rating must be at least 50v, the same as the old capacitors or more. The next voltage rating would be 63v.
      So I'd say pick any 50v/63v 10000-15000uF and you'll be fine, just check diameter and height and maybe the spacing between the leads of the capacitor (but that can be worked around if you want to)
      As for led mod ... it's simple ... formula is V = I x R
      Any led needs a resistor to limit the current going through the led so it won't burn up, so you need to figure out what resistor to use in series with the led.
      So let's say you want to use a blue led that has a forward voltage of 3v and you want to let about 10mA of current (0.01 A) flowing through the led... not too bright, not too dim.
      Therefore you have:
      Voltage - Forward Voltage LED = Current x Resistance
      14v - 3v = 0.01A x R
      => R = 11v / 0.01 = 1100 ohm
      So if you want to use a blue led and 10mA, you can use a 1000 ohm resistor or something close to this value to achieve the results.
        would this cap work?
        http://www.mouser.com/ProductDetail/...52bJszroGWs%3d
        for the LED mod im partly colorblind, it looks yellow to me, but others describe it as "a darker yellowish green" so should i use daylight white or green LEDs? i plan on keeping the original diffusers if that helps.
          use a high CRI white led or any coloured bits wont look right.
            Here is something you might be interested for the LED conversion: Onsemi makes an 20ma LED constant current regulator NSI45020. It can do up to 45V input but it has to be DC. Works great! Other than that, you have to work with voltage dropping resistors etc.
              grab this:
                ok, i removed the large filter caps and both test absolutely spot on. im just going to replace the failed lamps with incandescent lamps. screw trying to match colors i can't even see!
                  Is it fuse type lamps or Grain of Wheat type?
                  http://www.audiolabga.com/data_html/PRB-FL6.html
                    not fuse type, but not rice grain either. they are around 5mm(no calipers)
                      i will look at the manual later and give good advice.
                        the lamps are 14.5v 80ma and there are 8 of them.
                          thanks for the info, i will order replacements and post results.
                            Well, fuck sakes. I forget about a project for three years, and the thread for 4 years. I relamped it in '17 and just now remembered this thread.
                            Final outcome.
                            https://i.imgur.com/mQzYtwh.jpg
                            All warm white LEDs with the original diffusers. Sans dialpointer, anyway.
                            Im not sure why my camera picks up the dialscale as a sky blue. It's really not, but i couldn't really describe the color... I like it whatever it is.
                              Originally posted by CapLeaker View Post
                              Here is something you might be interested Onsemi makes an 20ma LED constant current regulator NSI45020.
                              Can you provide a link where you can buy them
                              When I googled it the first time I could not find any place that had any in stock
                              Never mind I found some here
                              https://www.mouser.com/ProductDetail...LmPs%2fA%3d%3d
                              I have a question is possible to use just one LED @ 5 volt with this NSI45020
                              From what I read in the data sheet it has to 1.8 volts higher than the LED or LEDs hook to it if I read the data sheet correctly
                              If this is the case then it slove a problem about a LED project that I been wanting to build for a long time
                              9 PC LCD Monitor
                              6 LCD Flat Screen TV
                              1 Dell Mother Board
                              15 Computer Power Supply
                              All of these had CAPs POOF
                                Looking good! I like it!!!
