Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices > Schematic Requests ONLY!
Thread Tools Display Modes
Old 01-20-2018, 03:36 AM   #1
lorins_core
City & State: Manila
My Country: Philippines
Line Voltage: 220-250VAC 60hz
I'm a: Knowledge Seeker
Post Acer Aspire V3-371
Hello there.
I need a Schematic Diagram For this Unit
MODEL: Acer Aspire V3-371-56LD
MOBO : VA30-HB MB13334-1
Problem: No power
1. I Check the Rail Of 19V have Supply
2. I Check the power Switch Ok.
3. I check the 5V ALW have
4. I Check The 3V or 3.3V ALW only 2.something
Any one can help me to Fix this. or if you have a Schematic Diagram. May I Copy Thanks
lorins_core is offline   Reply With Quote
Old 01-20-2018, 04:13 AM   #2
dspok
City & State: Cuttak
My Country: India
Line Voltage: 220V
Default Re: Acer Aspire V3-371
replace collector cap if it is not generating correct 3.3v ALW
dspok is offline   Reply With Quote
Old 01-20-2018, 07:42 AM   #3
JaroTech
City & State: Montréal
My Country: Canada
I'm a: Professional Tech
I found this, I hope it will help you.
JaroTech is offline   Reply With Quote
Old 01-20-2018, 07:32 PM   #4
lorins_core
Quote:
Thank Master I try it later and i re post it ok or not.
Old 01-20-2018, 07:33 PM   #5
lorins_core
Quote:
More Thanks Master. I try to view later and i re-post.
Old 01-23-2018, 09:01 PM   #6
lorins_core
hello to all
update on this unit:
I clean the mobo.
CHECK the Capcitor filter on Part of this PC4501 & PC4502 "no leak & no Shorted"
3.3V ALW mosfet Area PU4503 & PU4502 im compused for this? and why if inject (already plug the Supply Adapter) turn off.
have Supply out of 2V only @ 3.3v ALW- if i turn on the switch to power on. unit turn light indicator only on after off
checking the voltage on 3.3V ALW. have. but this Part no. PU4501 is heating up....
Any Advice
Old 01-24-2018, 12:55 AM   #7
lorins_core
Follow Up plsss
Old 01-24-2018, 07:36 PM   #8
lorins_core
Up please...
Old 01-24-2018, 09:54 PM   #9
vhn1998
City & State: ha noi
My Country: Vietnam
check PU4501: pin 3: 3D3V_AUX_S5??? if <3v3. check RTC_RST#, SRTC_RST# . I think error rtc block in haswell(cpu). replace CPU
vhn1998 is offline   Reply With Quote
Old 06-11-2019, 09:00 PM   #10
muklis
City & State: shah alam
My Country: malaysia
hello
muklis is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
