Apple 820-01326-05 after water spill not start
    Hello.
    I have this Apple 820-01326-05 that after water spill wont start.
    Chcrger works but charging is in loop. USB-C negotiate to 20V ok, slowly start charging from 0.4A to 0.9A and after that it reset to 0.05A and after 1 sec goes from 0.4A again. loop takes about 6-7 seconds
    I found 12.9V, 20.5V, 3.3V. no short.
    now i dont have schema or BV so i cannot measure more
    laptop was in other shop so i cannot find water spill corosion
    Re: Apple 820-01326-05 after water spill not start
    https://logi.wiki/index.php/Schemati...in_Logic_Board
    820-01326 ❌ ❌ Use 820-01041 boardview and schematic, 820-01326 unavailable, only difference is Vega GPU as far as i know
      thanks. interresting site.
      DOnt have enybody some starting list of rails for this newer macs?
        I found that U7650 have bad V5REG signal/only one pulse in2sec loop/so i replace IC. now i have stableV5REG, V3REG,G3_HOT, 3.3V ALW, but charger still charge untill draw 1A and then reset to 0.0A and start charging again
        i also dont have
          found
          SMC_SYSRST_L - 0.0V
          SMC_PCH_SYS_PWROK - 0.0V
          SMC_PCH_PWROK - 0.0V
          SMC_RSMRST_L - 0.0V
          so looks like my SMC is not work
            this guy have starting sequence diagram for A1990. where can i get one?
            https://www.youtube.com/watch?v=aTV7dAtSb9E
              https://logi.wiki/index.php/T2_and_C...ence#820-01598
                veeery nice. i came to half by screen capture his video, but this is way better
                found that this voltage loop works only on charger on battery i have steady voltage
                but still no work even only on battery. i found that CHGR_RST_IN_R is constant 0.0V and not reacting on power button. what is it state when work?
                  nobody knows what this signal suppost to look like?
                    i also dont have
                    thanks!
