+3VALW LINE SHORT Compal ZSO50 LA-A992P rev2.0
    Working on this mobo,
    Got 3VALW line short and #PROBLEM IS NOT FROM ALWAYS ON IC(PU301).
    I tried to get other short component but found nothing.
    None of the component is heating in voltage injection test.
    Guide me...
    I hv schematic for ZSO50 LA-A992P rev1.0
    which is same.
    Re: +3VALW LINE SHORT Compal ZSO50 LA-A992P rev2.0
    Guide me...
    which is same.
    19v line is ok.
    +3VALW is 0
    +5VALW is 0
    +3VALW & BIOS pin no.8 +3V_PCH is also short.
    checked Q30 after removing mosfet drain and source(pin 1&3) both are ground.
      Bios Pin8 if short-PCH gone(Can be for other reason but huge chances for PCH gone. In this mb its just one die with cpu+pch soldered onboard.
        see at page 12 RC285 and RC182 remove them und messure witch side is shorted
        when shorted side is +3v_dsw_p then cc70 or CPU is defect
          CPU+PCH is defected.
          Thanking you!
            Thank you!
