Re: Toshiba A665-14c
FETs can be difficult to measure accurately in circuit. Let's remember those measurements though. But keep in mind that PQ37 and PQ43 are in parallel, so you are measuring both of them at the same time.
We know the problem is someplace after PL11, but there are many possibilities still.
Desoldering things is still the only option you have available, so it's just about choosing what to remove. One possibility is to remove PQ37/PQ43 and put PL11 back. That will test all those capacitors that exist between PL11 and the FETs. It will also allow you to test the FETs outside of the circuit if you need to.
Test procedure for the FETs....
Source = Pins 1-3 (doesn't matter which)
Gate = Pin 4
Drain = Pins 5-8 (doesn't matter which)
Red/Black refers to the multimeter probe of that color.
Multimeter must be set to diode mode.
The expected reading is in parenthesis.
Steps:
1) Red on Drain, Black on Gate (No connection. This also turns the MOSFET off)
2) Red on Drain, Black on Source (No connection)
3) Swap the probe positions. Red on Source, Black on Drain (One diode drop, approximately 0.2-0.5V)
4) Red on Gate, Black on Drain (No connection. This also turns the MOSFET on)
5) Red on Source, Black on Drain (Less than 0.2V)
6) Swap the probe positions. Red on Drain, Black on Source (Less than 0.2V)
7) Repeat steps 1-3 to make sure MOSFET turns off again successfully
Be aware that some meters will not be able to turn on the FET properly. So this test isn't perfect. It should at least tell you if there is a short though.
Gate = Pin 4
Steps:
