Acer Aspire 5750 no B+ voltage
    Re: Acer Aspire 5750 no B+ voltage
    correct values
      Originally posted by multiplexer View Post
      correct values
      my measurements as follow
        correct values
        Better to put this way
          pq17 must be shorted or acoff is on.
          have one of these with bad pq17
            Possible faults:
            ACOFF incorrect value
            PQ17 short between the collector and emitter
            PQ14 short between pins 1-2 and 4-5
              No shorts on PQ17 or PQ14. there is only one option left i think and it is ACOFF . I assume ACOFF comes from KBC so do you advice to change it or there is a way to test it.
              PS. if shorted pin 1 and 8 of PQ7 the system works without battery fine if i insert battery and short the pins of PQ7 short occures on Power supply.
              i have not tested with the battery beause battery is empty and i dont have other one
                Measure the voltage on ACOFF PQ17
                Desolders PQ17 if your laptop is running (no short on 1-8 FP7) program bios U36, U38
                  ACOFF is 0v
                  removed PQ17 but no start
                  now flashing U36 and U38 then write the result here
                  flashed both kbc and main but the result is same.
                  there is one odd situation when i turn on the power the output of PQ7 rises slowly upto 0.8v and when i turn off the power the output drops down slowly to 0v. i took a video and share the youtube link soon.
                    PR38 fails
                    replace
                      Please attach your schema compare if it is equal to my
                        here it is
                          Here is the youtube link http://youtu.be/B78hyYI4xUg
                            PR38 fails
                            replace
                            removed PR38 and measured 47k as stated in the schema so PR38 is ok
                              My schematic is rev 0.1
                              I confirm check PR38 = 47K ohm
                              Thanks for the schematic
                                PR38 is ok 47K ohm measured
                                  Originally posted by ahmetozay View Post
                                  Thanks for the reply
                                  PQ14
                                  1=0v
                                  2=0v
                                  3=0v
                                  4=0v
                                  5=0v
                                  6=6.1v
                                  Measure the voltages on all the pins of Q8, Q10, Q14
                                  If you confirm these measures failure PQ14. Replace it
                                    Have you checked PQ6?
                                    checked the drain and source short.
                                      looks like ocp problem, Replace with the correct mosfet 4459, to be sure, remove PR14 and mesure again if you find 19V on PQ7 drain, please replace with the same reference;
                                        Checked PQ6 if it is short then 19v will comes to PQ7 gate and this FET will be closed and no output voltage to onward circuit so checked and repalced PQ6.
                                          well already checked and replaced nothing wrong there.i am stuck really.
                                          if i short pin 8 of PQ6 with pin of PQ7 system works without battery. the only reason is there is 0.25 v on the gate pins of PQ6 and PQ7.
