EVGA G3 series - fan needed.
    Anyone have a dead G3 series EVGA power supply handy?
    Is uses a 128mm fan. Need a working replacement. EVGA was no help. And in searching around, not finding much.
    Don't mind paypal'in a few bucks to someone for one. Thanks.
    Re: EVGA G3 series - fan needed.
    Is this what you are looking for
    https://www.newegg.com/Case-Fans/SubCategory/ID-573
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Nope, its probably a proprietary thingy:
      http://www.jonnyguru.com/modules.php...tory5&reid=500
        Are these power supply better than other brands
        Or they just okay power supply's
        9 PC LCD Monitor
        1 Dell Mother Board
          They are just OK, EVGA doesn't bring anything interesting to the table.
          The fans they use aren't that great either, fan noise is also not great.
            Is this it? https://www.evga.com/products/produc...400-HY-FX12-KR
              8mm too small...
                If this is not for a customer (or if the customer won't mind), why not just get a 120 mm fan and zip tie it? (Or if you are more handy, put some new screw holes on the case.)
                  I have used 130mm fans in those they fit with a minor drilling of the fan holes and the normal screws work fine.
