Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Old 09-17-2016, 09:09 PM   #1
ikelectro
City & State: Kolkata
My Country: India
Line Voltage: 230VAC50Hz
I'm a: Hobbyist Tech
Default ga-h61m-s1 motherboard schematic needed.
I need the schematic of following gigabyte MB ga-h61m-s1. the MB switching off immediately after turning on from Front panel switch.
thanks in advanced.
ikelectro is offline   Reply With Quote
Old 09-22-2016, 12:26 PM   #2
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Default Re: ga-h61m-s1 motherboard schematic needed.
Probably a shorted MOSFET on CPU VRM. Remove the 4-pin or 8-pin CPU power connector and try again: if the motherboard powers ON without switching off immediately, then the problem is likely bad MOSFET on CPU VRM.
Old 11-04-2017, 09:39 PM   #3
kubimz
City & State: Haiphong
My Country: Vietnam
Bạn có sơ đồ mạch điện của mainboard này ? , Tôi có thể hướng dẫn bạn sửa chữa nó . Hăy tham khảo 1 số bài viết với keyword " kích ngắt " trong diễn đàn này : http://tcomputer.forumvi.com/f41-forum tôi là quản trị viên của nó !
kubimz is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2019
