I have a LN52A750R1FXZA that turns on, the backlight turns on, I hear the little startup chimes, then the TV switches off. This loops indefinitely.
Here is a video demonstrating the issue and what happens when I disconnect the main board from the PSU.
https://youtu.be/0Z0mq7BCWU0
td;dw unplugging any combination the cables make the TV not react at all when power is supplied.
I tried removing the transistors from the board to check to see if all of them are working. With my DMM I tested that they were.
None of the capacitors on the board show any signs of bulging.
When I re-installed the transistors I realized the leads were a bit dusty. I used some deox-it on them, but when I plugged the TV back in the Q1815 transistor started sparking! I quickly unplugged the TV. I reflowed the solder points and made sure there were accidental no solder bridges. There are burn mark between the middle leg and the two outer legs. I tried it once again, it sparked again, and one of the fuses on the PSU popped.
