Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 07-11-2018, 06:35 AM   #21
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Has anyone used this module before Voltage Regulator DC 4-40V To DC1.25-36V 8A 20
if the controller says there is a sensor error then it shuts off power to the heater.
so if your heater was glowing you have other issues - either wrong wiring or maybe a shorted triac.
6pin pinout:
6pin:
1 - black (thermocouple+)
2 - blue (thermocouple-)
3 - red (heater)
4 - red (heater)
5 - white (switch)
6 - white (switch)
shell - earth(yellow)
stj is offline   Reply With Quote
Old 07-11-2018, 07:17 AM   #22
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
6pin pinout:
6pin:
3 - red (heater)
4 - red (heater)
5 - white (switch)
6 - white (switch)
That the way you think it should work but for some reasons it does not work that way I have even tested this by turning unit on and disconnecting the optic sensor and it does the same thing
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 07-11-2018, 08:28 AM   #23
stj
stj's Avatar
what optic sensor??
Old 07-11-2018, 10:18 AM   #24
sam_sam_sam
My Country: USA
That on ZD-917 switching power supply board and on the transformer power supply
There on both versions
Old 07-11-2018, 10:26 AM   #25
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
The resistance of the heater dictates how much current it will draw from the applied Voltage.
__________________
budm is offline   Reply With Quote
Old 07-22-2018, 07:37 PM   #26
sam_sam_sam
My Country: USA
Default Re: To control the heater element ON/OFF High Current 210A MOSFET Upgrade RAMPS
Quote:
Originally Posted by sam_sam_sam View Post
I do have a question
Do I put the print heat element controller first then the voltage regulator or do I put the voltage regulator then the heat element controller which way would be better and WHY
I have the answer to this question
It does make a different which one you put first
The voltage regulator module has to be first
The 3 D heater controller has to be second
( If you put it the other way you get a voltage increase on the power supply when the current starts going down ) <— this is not good for power supply what ever it might be
Then the 3 D heater controller had to be modified
The modification is as follows
Change the resistor for the LED incantation light from (103 ) to ( 102 )
Change the resistor for the optic LED sensor side from ( 103 to ( 102 )
Remove and jump the rectifier out
I have the setup working now but here is some interesting results
One
I set the voltage regulator to 4.60 amps —> from a cold start ( the voltage at the heater element is about 13 volts or maybe a little more)
Once It gets to about 30* F from the set point is starts backing down the amperage to 2.00 amps and hovers at this amperage ( the voltage at the heater element is about 9 volts more or less)
Second
With this setup it does not way over shoot the set point but it does take a little bit longer to get to the set point ( and settle down to a steady temperature)
It take about 25% more time with the battery setup versus the switching power supply setup
Which to me is not bad results I figured there would be some kind of trade off
battery power versus a switching power supply
Some more results
The heat sink for the voltage regulator module gets a little warm
The heat sink for the 3 D heater element controller barely gets warm
The results are very good for what I am doing with this setup
Now I have to mount everything in the ZD-915 power supply board, voltage regulator module and the 3D heater element controller
Then make a modified version of the Ryobi battery pack instead of a 4 amp hour battery changing it to an 8 amp hour with 6 amp circuit breaker for each stack of batteries
The reason for wanting to do this is that I want to use the Ryobi charger for this ZD-915 battery operated Desoldiering gun / soldering iron
Because this charger charges a 4 amp hour battery in 30 minuets when it is at 25% charged
When I have all the parts mount in the case I will post it in a new post
When I do the modified Ryobi battery pack I will also post this in its own post
Old 08-11-2018, 12:14 PM   #27
promo7uk
City & State: nottinghamshire
My Country: uk
well done,, yeah shows us how you did it, as good idea this,, and show us photos. be ideal for my son this who is a lorry mechanic, ideal for when hes out on jobs,, and needs to solder.
promo7uk is offline   Reply With Quote
Old 08-12-2018, 07:31 AM   #28
sam_sam_sam
My Country: USA
Quote:
I have this project on hold for the moment
By solving a problem that I was having with this project I solved a problem that I was having with another project that I was also was working on
That I am using the 3 D heater element controller module on both projects
I should get back to it shortly
Old 08-12-2018, 07:37 AM   #29
sam_sam_sam
My Country: USA
I have run into a problem with this project that I have work out
It has to with the heat sink for the mosfets on the charging controller board that is inside the battery case will not be big enough for the add amperage
So some how I have to resolve this problem
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
