USB variable voltage output power supply video feedback wanted
    Here is the video
    https://www.youtube.com/watch?v=dw3MehLAyWU&t=607s
    Here is where it goes into some details
    http://blog.deconinck.info/post/2017...e-power-supply
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: USB variable voltage output power supply video feedback wanted
    just keep in mind that a $4 usb psu will probably go boom at some point or make your circuit live!
      I have in mind using this switching power supply for this purpose
      https://www.ebay.com/itm/90W-USB-C-T...53.m2749.l2649
      This unit works pretty good I can select every voltage that it says that it can do
      I know that I not going to use a cheap charger unit for this purpose
      but I do have admit that it is a real temping to do this idea that you have do you have any charger in mind so could do what I have below—>
      I have not seen factory smoke lately and having withdrawals from not seeing any
      9 PC LCD Monitor
      1 Dell Mother Board
        i use an imax-B6 clone to get 80w and upto 24v in 0.1v steps.
        there is a nice clone with the added function of variable voltage & current psu-mode.
        (and an XT60 output connector - which is really good!)
          Just what added functions dose it have are you talking about version 2
          9 PC LCD Monitor
          1 Dell Mother Board
            not version2,
            a clone of the original with added software modes.
            https://www.aliexpress.com/item/33046267239.html
            DO NOT BUY THE PSU WITH IT.
            it's a 1.5A delta supply re-housed in a 5A shell.
            good supply - but not if you need 5A!!!
