this is one i have fixed a few times now broken motor wire then 2 door triacs blew changed door switch last time and its been fine till now .but this time it has me stumped .. water is filling as normal but its also pumping it straight back out . it gives e08 fault code .. not filling with water . but it obviously is or it would if pump wasn't running at same time ..
i will try and test the triacs properly tomorrow . i did test for shorts and none are shorted .
i tried disconnecting the pump for fun but the machine refused to start .
