Heres the deal.
    Re: Heres the deal.
    Originally posted by Pyr0Beast View Post
    Eh. Poor stuff makes you want to give up on what you do.
    It is sad to see people use cheap-shit irons, had to sand down the tip to make solder adhere to it. And afterwards it was moderately good to use.
    But compared to 45W weller ... It is junk.
    Also. Spending 20$ on an iron and then 40$ on a new one is throwing those 20$ away or buying 40$ iron for 60$ ...
    Waaaste of money ...
    This
      Re: Heres the deal.
      Hey guys.. real quick.. I placed the order a couple days ago.. then today i noticed on one of the caps i bought its a radiall cap.. the other two were FC SMD's this one is FC Radial... Did I order the wrong one....?
        Re: Heres the deal.
        Those should have all been radial, thru hole (as they go through the board). The SMD's mount on the surface.
          Re: Heres the deal.
          Yes all through hole...and radial.
            Re: Heres the deal.
            God damn it.. Thanks guys..
              Re: Heres the deal.
              I'm looking up the ones I'll need to replace... When I find them.. If you guys could just double check.. That would be great...
                Re: Heres the deal.
                I talked to a classmate in my Computer Science Class about soldering, he said something about demagnetizing the caps.. and I think I'm way over my head here.. In the videos I watch about soldering and desoldering I never heard or seen anything about what he was talking about..
                  Re: Heres the deal.
                  He probably meant discharging caps. The big main filter capacitor could hold a charge and you want to discharge it first.
                  Most modern lcd/tvs have a bleeder resistor and that discharges the big main capacitor after the power has been removed and unplugged in about 1 or 2 minutes.
                  You can verify if the big cap has been discharged by measuring its DC voltage with a multimeter.
                  --- begin sig file ---
                  --- end sig file ---
                    Re: Heres the deal.
                    Hey guys, like I mentioned before... I ordered the wrong one.. then just yesterday ordered the correct ones.. Anyways.. I desolder and soldered 4 of them I needed to replace... I must say its not all that hard (had I better experience and tools I wouldnt have been as sloppy im sure) Other then getting random drops of solder on the board..... it went pretty seemlessly. Now, it is a bit sloppy and if request is needed i can upload pics of it, but will some solder on the board in spots that serve no purpose mess things up.. its not globs of solder but kinda a smeared type of deal.... Thanks again guys for making this possible.
                      Re: Heres the deal.
                      So what's the outcome? Or are you still waiting on the caps and just practiced on the old ones.
                      A working TV? How boring!
                        Re: Heres the deal.
                        this kinda sounds like your solder is without a flux core..
                          Re: Heres the deal.
                          Hey guys! Sorry the rest of the parts just came two days ago.. been busy and just finished putting everythign on today.. put it all back together, and what do you know... IT WORKS! You guys are the best... 40 bucks and two solder burns later i got a TV, and learned a hell of a lot along the way which was worth much more than 40$, you guys have been a great help! Thanks a lot!!!
                            Re: Heres the deal.
                            Congrats on your first fix. Your already ahead of most of the Jarheads. Just kidding. Have fun with it and good luck with ROTC.
                              Re: Heres the deal.
                              This week has been amazing, on Monday I got accepted to The Citadel, and on Tuesday I got the TV to work! And thanks I appreciate it!
