Plasma Cutter Giant Tools LGK-60 not working
    I've got a Giant Tools LGK-60 Plasma Cutter here to repair.
    Complaint: It does turn on, the display is on, consumables had been replaced, when the trigger is pressed the air valve opens and that is about all she does.
    So I've opened that sucker up, checked the inverter o.k., checked the arc board o.k., came to look at the 400V 470uF main filter caps on the power supply and
    You think there is sumtin wong here? All 6 of them look like that!
    Re: Plasma Cutter Giant Tools LGK-60 not working
    That appears as heat related damage. Pull them out and check values. I'd opt to change them out for a start.
      Oh yeah... those got hot alright somehow and needed to be replaced.
        Does unit have a IGBT module if it does after you recap it that would be the next thing to check to see if it is getting the command to turn ON
        Make sure you replace the caps near the IGBT module if it has one
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          The inverter has a bunch of MOSFET's 2SK4108 in it and those are good. The rectifiers diodes are good too. I didn't see any other caps on the inverter board, when I took it apart, but I am going to have another look. Have to wait on what the owner wants to do anyway...
            What micro controller does it have
            9 PC LCD Monitor
            1 Dell Mother Board
              I don't know... didn't take it that far apart (yet).
              My theory right now, is that it is still a main filter capacitor problem. I did take a few of them caps out and checked them on my ESR meter. They show something like 20% down, with the ESR being at 0.22 Ohm. That doesn't mean they aren't breaking down at a higher testing voltage. I have a friend lined up with a proper tester that actually can charge the cap up to 400V and measures the leakage. We will see what happens.
                So I went and checked these caps with a proper high voltage tester. All of them have high ESR over 2.5 Ohms at rated voltage and leaking. That is exactly what I figured. I also came to find out that this Plasma Cutter was hooked up wrong at one point. That issue got fixed and the unit ran for a bit, then quit, then I've got it to repair.
                  Originally posted by CapLeaker View Post
                  So That issue got fixed and the unit ran for a bit, then quit, then I've got it to repair.
                  Where I work at this happen all the time or at least it seem to be the case
                  9 PC LCD Monitor
                  1 Dell Mother Board
                    yeah, for some reason most of the time it always ran after an event for a lil while... I don’t think it was running any after that whatever happened to it..
                      So...got the new replacement caps, put them in and the plasma cutter still does the exact same thing. No workie. Grr. Guess I am pulling the arc board next, unless someone has a better idea.
                        Can you please post the photo of all of the boards in this unit
                        9 PC LCD Monitor
                        1 Dell Mother Board
                          Well, I don't have all the boards out, but I did take out the PSU and the arc board. I've rechecked the PSU and that is 100%, even took the blue relay and the mosfet out and tested it o.k. Also checked the Thermistor (little black box) o.k.
                          Now to the arc board: All diodes, transistors, caps and resistors are good. Can't find anything wrong. Those green PTC's measure 450 Ohm and the other 530 Ohm. Kinda weird value or something?
                            does it have an arc gap like some tig welders ?
                              I would also add this you need to find out if it is getting the command to ( fire )
                              start if not why not and do the 4 big caps getting any power
                              9 PC LCD Monitor
                              1 Dell Mother Board
                                Yes (second pic, where the 3 blue HV caps are, marked F00), I cleaned those and played around with the gap to no avail.
                                I know the trigger works, a relay clicks and air comes out. However, I am not sure if the arc board is getting the command to fire. I've got no schematics or anything to go by. The PSU is 100% and power is available.
                                  Here are more pics. All fets and diodes are good. All resistors at each of the fets are good. All big wire wound resistors are good... there is nothing I can see, but it still isn't working. The relay on the PSU is good, the relay on the arc board is good too. The temp sensors are good and slowly I am out of ideas. The control board is on the top, next to the inverter.
                                    continuity to torch for sanity
                                      no idea how they work but i see high voltage caps in there that may be leaking .. just a thought like .
                                        been there and checked out good.
                                        Well, I gave it more thought: The arc board (or HF board) only can arc, if it has power and that comes from the inverter board. If the inverter doesn't switch on, I am thinking that the arc board won't switch on either. That leaves the control board (or driver board for these fets) and the driver transformer board. After all, if the fets aren't driven from a PWM, then there is no power, right? Maybe the PWM is fubar? Food for thought.
