I still need a cyan printhead
Look what a customer gave me
^If you have datasheets not listed PM meTags: None
Re: Look what a customer gave me
Ugh it turned out sidewaysCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by ratdude747 View PostA paperweight?
The only Inkjets worth using are photo printers (for those who print such things) and large format (plotter) printers... Consumer ones are hopeless paperweights and a joke compared to laser printers.
I have a brother MFC-9125CN laser printer and would never think of buying the inkjet crap again.
Adding insult to the injury of buying an inkjet is the wireless only ones. Never would I own a wireless printer as there are too many issues with connectivity.
Look...closerCap Datasheet Depot: http://www.paullinebarger.net/DS/
This one, did not. Made custom in japan. The printer itself also wasn't a chepo (at least at the time it wasn't). Has an ethernet port too. Hp eprint even works on this old thing on my phone.
Each head has a load of 24,000 pages
Thing is you have to print once a week or it clogs. Also the heads are getting harder to findCap Datasheet Depot: http://www.paullinebarger.net/DS/
I have found that most of the time, the trouble with inkjets is the ignorant owner. For example: My parents printer has stopped putting out ink, several times and it was always because of the ink drying up in the nozzle. Just pull the cartridge, and dab the nozzle (in the print cradle, not the ink cartridge) with alcohol, run a head-clean procedure and *BAM*, it's back to printing.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
KABLAMMY goes the inkhead!(when it jams)Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic
i always find that hp printers have a lot of problems like nozzle failure,no paper detection,and stuck paper in rolling mecanism so i consider them as the crapiest printers i have ever work with, now i have a brother dcp 195c printer that i find lying on the street waiting the garbage truck because an idiot has broken the cartrige detection sensor on the black color i shorted that with a bit of solder and its working like new also more reliable than hp printers she just do what is supposed to do
this thing has been used by my customer constantly, for years. No jams, only issue he had is with the heads drying up. I found some heads finally, CMY, new for $49 bundled, free shipping. He had an unopened black head I already put in
Its a businessjet 1200, its built for high volume printing, but the heads are built like crap if you go without printing for a long enough time, but I think I have that problem solved. On my Ubuntu server I added the printer as an IP printer in CUPS, and have a cron job set to lp a pdf that contains a CMYK print test page every day at 4pmCap Datasheet Depot: http://www.paullinebarger.net/DS/
Well well. This printer has displayed some issues.
*startup light blinks, then printer turns off
*middle of printing lan connection drops, printer soft reboots
*unstable high pitched whine from the back before successful power up
As I suspected...fucking taepo
Im guessing sc105c is model and obviously max temp. Taepo pdf says for switching power supplies....so panny FR?Last edited by Uranium-235; 11-03-2016, 11:06 AM.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Shame on you!! Cap check is a standard with any free hardware!!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Originally posted by Topcat View PostShame on you!! Cap check is a standard with any free hardware!!
But im afraid the unstable voltage damaged the magenta cartridge chip, now reading 0Cap Datasheet Depot: http://www.paullinebarger.net/DS/
