HP15-P228NA Black Screen (DAY12EMB6C0 REV C)
    hope someone can help i have a HP15-P228NA laptop that powers on to a black screen, not getting any signal even on the HDMI output.
    the power led just stays lit, no sound from the speakers (beeps).
    HP15-P228NA
    DAY12EMB6C0 REV C
    Model: Y12E
    Re: HP15-P228NA Black Screen (DAY12EMB6C0 REV C)
    try the basics.. test a known good memory, check all the power rail.. specially the ALW voltage. inspect the board for burned parts.. check the bios ic for vcc and rtc battery 3v and post the voltage here..
    Never stop LEARNING because life never stops TEACHING!
      tested different memory. still nothing.
      theres 3.2v on bios chip pin 8
      attached some voltage measurements.
        Flash bios first.
          this unit is using a DDR3L PC3L-12800 1600MHz SODIMM...make sure your using the correct memory module. DDR3L is a dual voltage capable memory DIMM, which supports operation at both 1.5V and 1.35V. DDR3L is also pin-compatible with DDR3! DDR3 is a single voltage capable memory DIMM, which supports 1.5V operation only.
            Originally posted by mcplslg123 View Post
            Flash bios first.
            i flashed bios. see
            https://www.badcaps.net/forum/showth...642#post980642
            used the same spec memory.
              did you repair the laptop? what is the status..
                Not yet. It worked for less than 5 minutes.
                See here when I flashed the bios what happened.
                https://www.badcaps.net/forum/showthread.php?t=87547
