Howdy all at BdCaps purchased one of these transistor capacitor testers from you know where. Had it a few months and now the thing wont power on, the power on led just blinks and display don't light up. I've checked the voltage on the 9012/9014 NPN BJT Transistors and they measure within specs from pin 1 emitter and pin 2 the base and all the way to the pins of the digital display. Has anyone had
Transistor Tester crash
Re: Transistor Tester crash
Originally posted by redwire View PostCheck if the HT7550 LDO is making 5V for the MCU and display. The 9012 PNP transistor switches on power to start the 5V regulator, and then the MCU is supposed to run and keep the 9014 /9012 on.
now to find a replacement or equivalent thanks bro, hope this fixes it!
There is some info on this device here https://goughlui.com/2016/10/27/proj...or-tester-kit/
along with a hand drawn schematic if it helps.
Originally posted by R_J View PostThere is some info on this device here https://goughlui.com/2016/10/27/proj...or-tester-kit/
Originally posted by manstoblame View PostWould you know of a substitute I could use in place of the 7550
