Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > MSI/Microstar
Thread Tools Display Modes
Old 01-15-2020, 08:48 AM   #1
victor-r
City & State: Ericeira
My Country: Portugal
I'm a: Knowledge Seeker
Default Msi z97-g43
good afternoon
I need help, MSI Z97 motherboard with a shorted IC (UP0104S), I can't find anything that will help me find at least one equivalent IC if anyone can help me
victor-r is offline   Reply With Quote
Old 01-15-2020, 08:50 AM   #2
victor-r
Default Re: Msi z97-g43
I'm sorry I was wrong in the place to post wrong place
Old 01-16-2020, 07:30 AM   #3
victor-r
Good afternoon
if anyone knows and can help me, know the IC uP0104s, without datasheet
Old 01-17-2020, 06:35 PM   #4
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
I can't seem to find a datasheet either. But looking at images on eBay, it looks either to be a regulator of some sort or a MOSFET... or less possibly, a controller for a VRM.
Are there thick traces connected to any of the pins on this chip? Any of them low resistance reading (under 100 Ohms) to ground? If yes, it's probably a regulator or MOSFET.
Somewhat good news is that at least they are available to buy on eBay. So bad comes to worse, maybe replace it if in doubt.
Also would be good to know more about your motherboard troubleshooting: i.e. what is the board doing and how did you conclude that this component is shorted? Does it look burned or with a hole in it? Heat-discolored? The more we know, the more likely someone may be able to point you to a solution.
Old 01-18-2020, 04:26 AM   #5
SMDFlea
Moderator
City & State: York
My Country: UK
Here`s a schematic for an MSI Z87-G43 ,check page 31 aND 37.
SMDFlea is offline   Reply With Quote
Old 01-29-2020, 05:31 AM   #6
victor-r
Ok thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
