Re: Benq G2255 doesn't power on - amber power light when plugged in - part 2
Ok, I did find a few 5V to 3.3V regulators but they are SOT-323 instead of SOT-252. Do you think that could do it or will it heat up to much? I could add a small heatsink if you think it could work?
part number FS1117 33GJAD02. On the same board I also have a 1.8V regulator in the same format SOT-252 in case something goes wrong with the one on the main board.
PS - I had found a SOT-252 on a video card but it was so difficult to remove with hot air, I had to crank up the heat to 390 and I either killed it or it was already bad, because I have 0 ohms from input to ground but ok resistance from output to ground.
Question Will: Could the 5V line not be clean and that is causing the issue and also killed the 5V to 3.3V regulator..or am I just being paranoiac ? Also, I got a new hand held oscilloscope AllSun EM125 wich is supposed to be 25mhz, but just starting to know it...but if I can do better checks than with the former one, I'll do them. I'll also be getting tonight a used Leader 1020 oscilloscope that seems to work fine. I'm pretty sure I'll be able to do more tests with that thing!
