Led array
    Led array
    Hi all
    Just wondering what you guys use to refit the Led diffusers once you've replaced the bad smd led.
    Re: Led array
    Originally posted by Rickig View Post
    Hi all
    https://www.walmart.com/ip/2pcs-220V...21mm/125800679
      Re: Led array
      Not sure what that's for
        Re: Led array
        You buy those PTCs and build something like that
        https://www.youtube.com/watch?v=EZVQKEp6jxk
        For Led diffusers i use BISON ADHESIVE PLASTIC
          Re: Led array
          I just use cheap super glue as an adhesive for the lens. I use a hot air station to remove the old SMD LED.
            Re: Led array
            What temperature is your hot air set to?
              Re: Led array
              To some extent it will depend upon the device and the manufacturers data sheet, I don't really have a temp set in mind for my pace hand tools, but aim for between 260 and 300 degrees if there is a large thermal mass indicated then higher. It all really depends on experience.
