Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 01-07-2018, 11:01 AM   #1
johnfin
City & State: tampa, fl
My Country: united states of america
I'm a: Knowledge Seeker
Default Scr / thyristers
If the schematic calls for a 200v scr can i replace it with a 400v scr?
johnfin is offline   Reply With Quote
Old 01-07-2018, 11:16 AM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Scr / thyristers
Yes, as long as the other parameters ar also as good or better ie: current
R_J is offline   Reply With Quote
Old 01-12-2018, 07:31 PM   #3
Longbow
City & State: Brighton, U.K.
That particular spec means that the device has to withstand at least 200v. reverse. But there are other important specs with thyristors, especially the turn-on voltage and turn-on pulse width required. Also, you need to look at requirements for the reverse voltage width. If too narrow, the SCR won't turn off. Or, you could just slap in the replacement and look for smoke (just kidding).
__________________
Is it plugged in?
Longbow is offline   Reply With Quote
Old 01-20-2018, 04:26 PM   #4
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
What are you going to use it for resistance load or on a inductive load ?
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
