Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 09-15-2017, 05:35 AM   #81
rievax_60
City & State: mackay
My Country: australia
Line Voltage: 240
I'm a: Hobbyist Tech
Default Re: Pioneer VSX-520-K Protection problem
Originally Posted by rievax_60 View Post
Ok, that helps to make sense of the voltages. The leakage has to be between collector and base pads of Q444. Try to clean it again. Do you have any information about the flux?
That was a mistake. The leakage would have to be between collector and emitter.
rievax_60 is offline   Reply With Quote
Old 09-15-2017, 05:36 AM   #82
srt1
City & State: calicut
My Country: india
Flux shows neutral PH7+-0.3..so i think its neutral
srt1 is offline   Reply With Quote
Old 09-15-2017, 05:38 AM   #83
rievax_60
Line Voltage: 240
Did the PCB get burnt under Q444?
Old 09-15-2017, 05:41 AM   #84
srt1
My Country: india
Flux shows neautral..its written ther PH+-.3
Old 09-15-2017, 05:42 AM   #85
srt1
My Country: india
Yes littile burn mark ther
Old 09-15-2017, 05:44 AM   #86
rievax_60
Line Voltage: 240
I would use a small drill bit to remove the burnt paper from between the collector and emitter pads.
Old 09-15-2017, 06:21 AM   #87
srt1
My Country: india
I am.trying to remove the burn mark..and let you know the result
Old 09-15-2017, 06:50 AM   #88
srt1
My Country: india
Hi.. i replace the 2sa684(q444) with a92 now problem soleved ther is no leakage current. I think 2sa684 for not suitable for this apllication as the maximum volatage on Vceo is 50 but in this circuit its 54volt i think thats why this leakage current but for a92 Vceo is 300 volt.any way thanks alot for your support i apriciate it..may be tomorrow i will get correct tramsistors ie. A992..then i wil replace it
Old 09-15-2017, 06:57 AM   #89
rievax_60
Line Voltage: 240
The 2SA684 would not have had any leakage and there was no indication that Q443 was leaky. If the PCB was charred, you should confirm it. I like things to make complete sense where possible.
It is best to use the correct transistors.
Old 09-15-2017, 07:03 AM   #90
srt1
My Country: india
The 2SA684 would not have had that much leakage and there was no indication that Q443 was leaky. If the PCB was charred, you should confirm it. I like things to make complete sense where possible.
Yes i done cleaning and same time i replaced transistor also ..i think you are right may be black mark cause leakage ..but any way i will replace with correct transitor tomorrow.because if i put back 2sa684 for testinfg freequent removal causing traces damage..
Old 09-15-2017, 07:44 AM   #91
srt1
My Country: india
Today i got onkyo sr 313 and pioneer vsx 1122 both are ahutdown itself after power ..i will open another thread for discission..
Old 09-15-2017, 10:16 PM   #92
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
What Voltage do you have at the Base of Q437 compared to working channels?
What are the Voltages at the Collector of Q443, 444 compared to working channels?
Old 09-15-2017, 11:34 PM   #93
srt1
My Country: india
At base of q437 was around 49 volt with respect to ground.and cillector pin of q443 444 is -53volt .its almost same comoared to other channel..
Old 09-15-2017, 11:49 PM   #94
budm
budm's Avatar
So those Voltage readings on all those 3 location as I request show about (within 1V) the same as in the working channels. There must be some readings in that section that is/are not the same as working channels.
Old 09-16-2017, 01:28 AM   #95
srt1
My Country: india
Yes that is at base of q443 q444 and at the emitter tied
