Av123 MFW-15 power supply problem
    Hi, I recently bought this sub. However, the person that sold it told me that the power does not work but the sub is still usable if I hook it up to a separate amp. I was able to hook it up to my Inuke6000 DSP and the driver works.
    Turning the power on the sub and set it on auto will lit up the green light but If I i select auto it will lit up the green light for a short period of time but shortly after that, it will turn back to red.
    I also smelled burning smell inside the of the sub. I opened it and discovered several capacitors burn/ blew up.
    As for the power supply board, the C4, R1, R2 capacitor is blown.
    The power supply listed as MFW-15_POWR v2.1 and I listed in the attachment below.
    I found several links that showed how to replace the capacitor to fix the hum but not to replace the other broken capacitor. Can someone point out what is the value of the R1 and R2 capacitor and which capacitor I can replace it with?
    Any help would be appreciated thanks,
    https://imgur.com/ZiVn2RT that is the link to fix the hum with the replacement capacitors.
    Re: Av123 MFW-15 power supply problem
    https://www.badcaps.net/forum/attach...2&d=1519405455
    Can I get straight shot pictures wit less glares so I can clearly see the traces?
    The resistors looks to bleeder resistors to discharge those 4 large filter caps, the small ceramic disc caps are for high frequency filter and they are connected in parallel with those big caps.
    BTW, you also have bad brown problem, they are corrosive and conductive and must be removed.
    Can we also get good clear pictures of other board as well?
      Yes sir, i'll update it tomorrow currently at work. Thanks for the quick replied.
        I am currently trying to repair this same amp.. mine is blowing fuses. I have r1 and r2 1 leg unsoldered to test, it's reading .692 on both r1 and r2. I removed D1 diode cause it was letting voltage go both ways ( I suspect thats what is popping fuses) the R1 on the other board you can see has a chip in it but reads out at .692 like the other one altho both them have different color bands...
          Ceramic discs are 104M 50v Y5u 1nf 20%.. your resisters in R1 and R2 are different colors than mine and they are the same boards. I can't tell for sure what the color bands are on mine either sucks.
            <Nevermind, i mis-read some things>
              What resistance do you get when measure the resistance between the two legs of C4, between the two legs of C5?
              I am still waiting the straight shot pictures of the bottom side of the board with less glares so i can trace out the circuit.
              Your board also has those nasty brown glues that will conduct and eat away copper traces and component's leads.
                Sorry for the late update. Can this power supply be fix or salvage?
                  OK, R1. R2 resistors are just bleeder resistors to discharge those four filter caps.
                  C4 and C5 are connected in parallel with the big filter cap for high frequency filtering.
                  The R1, R2, C4, C5 are not needed for the circuit to function, you can remove the burnt cap for now.
                  Right now we need to verify if you do have all the Voltages coming out from the power supply board or not.
                  Please check the DC Voltage with ref. to the GND pin of the connector
                  CN4B (for running the power amplifier section) and see what you have on:
                  I expect the +/- VCC to be arund 35 ~50VDC range, depends on how powerful the amplify is.
                  -VCC pin
                  +VCC pin
                  +VCC +15V
                  CN5B (this is the +/- supplies for running the pre-amp section): with ref to GND pin
                  +15V
                  -15V
                    98nf 15ohm esr on c4 and 96nf 15 ohm on c5
                      I am talking about just plain resistance reading using Ohm meter, we are trying to find out if those caps have leakage resistance or not, it is not the same as ESR.
                      Those ceramic caps tend to fail as shorts circuit and burn up.
                      See post #9 too.
                      This power amp looks to Class D amplifier.
                        See post #9 too.
                        2.765k on both when measured on my auto range multi meter on ohms.
                        On a side it doesn't blow fuses if I leave it unhooked like the pic I'll attach, but soon as I hook up the remaining boards fuse pops instantly.
                        Thanks for the help on this. Hope I don't make you pull your hair out. I'm kind of a noobie.
                          The cable that you unhook is for +/-VCC power supply to run the power amplify section.
                          There are 4 3-pin power devices attached to that black metal plate/chassis, I believe that is where the shorts circuit is.
                          You will have to remove the two metal clamps that hold the devices against the plate so you can see the P/N.
                          This is not going to be an easy job because those devices are direct coupled so when one goes bad it causes the chain reaction and takes out other devices with it.
                            So I ripped it all off the plate as you mentioned. Seen some browning on the fets so I check them with a multi meter and one on each bank tested OL, so I pulled them and 2 of 4 are completely wide open then I noticed all 4 are from different batches... So question is perhaps thats reason for fuses blowing? P.S. this glue is horrid.. lol since 2 of these are dead, I'll have to replace the driver transitors also? I don't have an oscope to test the driver waves, mine had a fight with a cup of coffee and lost the battle.
                            EDIT: I put one of the good fets in each bank L@R and powered it up and presto green light. I'll order 4 of these IR807P's from digikey or mouser so I have 4 of the same batch. Going to replace the driver transistors right away too.
                              Thank you for your efforts. Replacement IR807P's will be here in2 days, hopefully after installed I don't fall victim to that hiss. I will be recapping all these boads while I wait for the 807s tho. Cheers
                                The MOSFETs are actually IRFB31N20D, the 807 is just some date-code thing, see page 8 of the datasheet:
                                To double-check them, use the diode-test mode on your multimeter, black probe on the middle leg (or the metal tab), and red probe on the right-most leg; normally (ie. on a good MOSFET) you should get something around 600mV or so voltage drop across that, and "OL" if you reverse the probes.
                                MOSFETs usually fail shorted, so that would explain the fuse-blowing.
                                  I called them 807s for short, I tested them in my cheap ebay tester as well as with my multimeter one probe on the metal back than to each leg, getting a beep on all 3 and viceversa. the 2 that were wide open on all legs I tossed the other 2, like I mentioned I put back in 1 in each bank and turned it on and got the green light then pulled them back out and tossed those also, cause all 4 of them were from different batches and I ordered 4 new ones of the same batch. 7.99 for 4 and 7.99 for shipping. Orignally ordered from digikey but got an email saying they didnt have 4 of the same batch for sure.. so went to mouser and got 4 there of the same batch. But I did get all the replacement caps for all the boards from digikey still. Should all be here in a few days, once I get it all installed I'll post the results.
                                  https://www.mouser.com/ProductDetail...jAq5UtOClqM%3d
                                    -VCC pin
                                    +VCC pin
                                    +VCC +15V
                                    +15V
                                    -15V
                                    I'm sorry, I'm fairly new to this, do i have to hook up the power supply board back to the amp and power up to do the volt measurement? Or i just measure without it?
                                    And by measuring it, the black com will be on ground and the red cable will be on the point you going to test?
                                      No, that's just to make sure the power supply board and the transformer both work as intended. And yes, for the probing.
                                        @ khron. So hook the power supply board back to the amp and power it on to check correct?
