I have a Samsung P2770H monitor, on which I replaced the main board because it has an issue that it would restart itself every X minutes, that resolved that issue.
Now, a few months later I turn the pc on and find 3 1px vertical green lines on the monitor, the lines wont show up on a screenshot. Does the same with dvi or hdmi.
I opened it up and made sure the panel connection to the board wasn't loose and the flat cable looks ok. Pressing the connectors while the monitor is on sometimes changes the line colors from green to blue or yellow, but the lines are always there and no new ones appear.
I tried disconnecting the flat cable when the monitor was on, and it goes all white, without the vertical lines, so I guess the panel is fine and it's something on the board. I inspected it visually and nothing looks burnt.
This is the board:
Is there some component known for causing this type of issues I could check? Because I still have the old board with the reset issue I could salvage some components from.
This is the board:
