Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 11-14-2017, 02:12 AM   #1
pope3909
City & State: Georgia
My Country: USA
I'm a: Knowledge Seeker
Default SST-ST45SF-G failure 3.3/5/12 lines but not ps_on or 5vsb
I have a SST-ST45SF-G that has failed on all of the 3.3/5/12 lines, but the ps_on (green wire) is reading 3.7v and the 5vsb (violet wire) is reading 5v. I disassembled it and checked for any swollen or shoddy looking caps but found nothing. No components are discolored, nor do I see any scorching. It all looks perfect. It's a SFX so it's possible i missed something but i looked very closely. No sounds or fan movement either, even when the paper-clip test is done. I tested everything strait from the PSU with no cable attached to make sure that wasn't the cause. The fuse checks out as well. I checked the back mosfet but there may be one more I havent looked at yet i'll have to check. Does anyone with more experience than me (so practically anybody lol) have a probable cause to this failed PSU, or a push in the right direction?
I'm trying to get on a good level with electronics repair but I still have a lot to learn. I got this PSU for practically nothing, but it's very expensive (new) and I'd really like to fix it for my mini-ITX build (also using salvaged parts). I've already replaced an r36 inductor on a FM2A75M-ITX (and created a custom heat-sink for all the inductors since they are famous for burning out (like this one did) on this model mobo. It's more than just saving money though, I want to be able to diagnose things better. I just need a push in the right direction.
pope3909 is offline   Reply With Quote
Old 11-14-2017, 12:01 PM   #2
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
Default Re: SST-ST45SF-G failure 3.3/5/12 lines but not ps_on or 5vsb
Pictures would be a big help.
Basically there are two almost separate power supply circuits inside that box: the Standby regulator; the main outputs.
The Standby circuit provides 5VSB to the MB and housekeeping Vcc for both the primary and secondary sides of the main regulator. The Standby circuit appears to be working, since you have 5V on the 5VSB (purple) wire.
You mentioned 3.7V on the PSON# (green) wire. Is that plugged into a MB? Or is the PSU not connected to anything? For the PSU main outputs to turn on, the PSON# signal must be low. If the PSU is not plugged into a MB, short PSON# to return. This will turn on the main outputs if the PSU is OK.
__________________
PeteS in CA
Where might is right
There is no right.
- Sophocles in "Antigone"
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
PeteS in CA is offline   Reply With Quote
Old 11-14-2017, 02:08 PM   #3
pope3909
My Country: USA
It's apparent to me that anything beyond the obvious (physically damaged components) are out of my scope since I only have a basic electronics understanding (my professional field is clinical laboratory science.) If it's not an leaky cap or a failed diode then it's beyond me and i'll just junk it. Sorry to have wasted your time.
Old 11-14-2017, 02:09 PM   #4
pope3909
My Country: USA
Disregard the images. What I suspected as a discolored component was actually just a drop of factory flux that cleaned off.
Old 11-14-2017, 02:21 PM   #5
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Technically it's glue: used to hold the SMD components in place as the board goes through the solder oven
__________________
Per Hansson is offline   Reply With Quote
Old 11-15-2017, 05:58 PM   #6
Quaddro
Tukang Kentu
Quaddro's Avatar
City & State: Yogyakarta
My Country: Indonesia
Line Voltage: 220VAC 60Hz
I'm a: Hobbyist Tech
faulty all voltage rail, usually happens due to faulty of optocoupler area.
Check or replace the optocoupler(s), and also check the all component surrounded.
Quaddro is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
