Hello , I have this 3060 EVGA card that doesn`t work . Measured for shorts and resistance , seems ok . Powered it up but doesn`t work , GPU chip is cold . Though this part circled in red is getting very hot and pretty fast so I suspect this is the reason . Can somebody help me discover what this part is . Maybe a data sheet or a similar part ? Thanks
RTX 3060 EVGA - Part Discover Help Needed
Re: RTX 3060 EVGA - Part Discover Help Needed
Originally posted by Bozog View PostIt looks like its the 5v rail buck regulator, but on the only schematic I can see its a MP1475DJ which has different markings, so possibly an equivalent chip from a different manufacturer.
do you have a boardview or schematics for this card ? I got no voltage on most rails unfortunately and I don`t know ehere to look .the only thing that I can notice is that that part is getting really hot and I presume that is the main factor
Originally posted by Bozog View PostSurely tho, if there is no low resistance to ground on that 4r7 coil next to the hot chip, then the chip itself is faulty.
Originally posted by Bozog View PostWell ideally you would inject something like 0.8v@3a on this coil and see what gets hot, but you'd need a lab type power supply for that. This could just be a shorted capacitor, which you maybe able to spot on close inspection.
Luckily I have one
The same voltage regulator got hot around 3,5a on 0,9v
Hi Goblin Can you fix your EVGA ?
i have exactly the same issue... i find that MP1475DJ doesnt get the Enable Voltaje, and the UP9516 #PART U14 "PEX SWITCHER" The same hasnt enable voltaje....
i have order the 2 ICS and will change it.... i will publish my result asap
