I got this unit (original surface rt) without any operational history. It fails to power up. Cosmetically, the unit does not have much / any wear signs. The original power adapter light illuminates when connected (doesn't necessarily mean much as it lights even with the battery disconnected from the connector). The power pins show 12v on both output pins. Opened up the unit and checked the battery. Initially, it was showing only 7v (battery rated at 7.4v). Cleaned and reseated the cabling. Left it plugged into ac over night. The battery now shows 7.8v which seems to indicate some form of charge. The result is still the same, no start up. I have tried holding down the power button for 10 sec and then release followed by a tap on the button to attempt a restart up. Nothing. I have tried a few others suggestions that I have found on the net (holding down the volume up or down key with power button, three quick taps on volume up / down, etc).
Was wondering if anyone here has any experiences dealing with these "old" pieces of "technology"? One other thing, I should note is that I plugged into the usb port with a cable to try charging another device from it as I expect that most computer usb ports can / are power charging capable. Nada. I have not dug into the port area yet to see if anything is amiss.
Thanks for any help / guidance to give this thing one last "breath of operational life".
