Dell E6540 No RAM detected.
    Re: Dell E6540 No RAM detected.
    Originally posted by Andreasbest View Post
    Correction: SIO_SLP_S4# @PR203 is 5V
    Do you mean PR206? 5V would be PR203 which makes sense since it coming from +5V_ALW
    SIO_SLP_S4# goes to PR206. But again, as mentioned before measure everything in the power sequence first then post your results.
      Correction again: SIO_SLP_S4# @PR206 trace is 0V as there is no PR206 in soldered.
      SIO_SLP_S3# @PR607 is 0v (with or without the led blink error)
      Next is SIO_SLP_M# and SIO_SLP_LAN#, i translate correctly the schematics?
        Its SIO_SLP_A# (not M#, otherwise yes), SIO_SLP_LAN# then SIO_SLP_WLAN#.
        Not worried about PR206 (for RAM section atleast) since it is no stuff and not used to turn ON the IC (see Item 6 on page 75 of Version change list)
          It's a typo? In Schematics i see clearly M.
            Ahan, I didn't see the M. Looks like a typo, should have been A.
              SIO_SLP_A# @PR303 (not present) 0v
              SIO_SLP_LAN# @RH80 has 0v one pin and 3.3 on the other (not present too)
                Proceeding to rest morning, brain must enter S5 state for at least 8 hours
                  The case may or may not be solved, but i appreciate the time and effort dedicated by@spider1211. All the best to@andreabest.
                    Goodmorning and thank you very much @mcplslg123 !!!
                    +3.3V_M @U102 pin 13 & 14 3.3v until the led error occurs, then 0v.
                    PM_APWROK_R @UH2 3.3v until the led error occurs, then 0v
                    1.35V_MEM @RD2 1.35v until the led error occurs, then 0v
                    Want to keep measuring??
                      If 1.35V_MEM is coming on that means SUS_ON is also coming on. Measure SUS_ON and check. After how long does the error come up after turning on? Does fan spin?
                      Measure the voltages requested in post #4 and report back. Check of there is voltage on all the coils before error occurs.
                        I'm sorry for the delay i feel so embarrassed, i found the "problem".
                        The CPU needed resitting and i can't understand why i didn't think about it earlier.
                        I'm really sorry for all your time i wasted, i promise it will not happen again.
                        Thank you very very very much and again sorry
                          LOL, it happens. Lesson learnt I hope
                          Interestingly enough, I recall asking you to check that same thing on another post of yours.
                            Really? You asked me to resit CPU???
                              Not in this thread, it was another one.
