I have this motherboard from the title, there is no schematic or boardview.
When i apply the adapter nothing happens, no lights, only little buzzing noise but adapter is not going to protection mode. Later i check and on first power mosfet there is 19,3 v but later nothing (it is not opening)....Then i check again and every time i apply the adapter it will open the second power mosfet but voltage is just droping...9v...6v...3v...0v
So, i believe the power main controller is closing power mosfets and going to protection mode because ther is a short somewhere in lower power lines?
I checked i believe every coil and most of the current sense resistors and joints but i couldnt find anywhere short to ground.
I have lab power supply and i was thinking to inject voltage/amper but i am not sure how and what? so can anyone help me because i am new in repairs.
So what is obvious is that i will not inject 19volt on second power mosfet because the "protection mode" is activated for a reason and i will probably burn something.
Can someone help me what voltage and amper should i inject and where to to find a short?
Thank you!
Thank you!
