I'm working on a Hisense 58” R6E3 $398 Walmart special Roku TV. I picked it up free as the previous owner just said the picture went black so I assumed I'd be doing LED strip repairs. As it turns out the backlight is working fine, the TV responds to remote signals as I can here the typical Roku menu sound effects. My first thought after some typical voltage checks was a bad t-con board so I ordered an eBay damaged set pull for $5. Swapped it out and no change.
Before I order a replacement main board, I wanted to see if anyone else had seen similar issues with this set? I pulled the bottom bezel and don't see any signs of damage, physical or liquid to the driver boards and ribbon cables. Other than a few scratches on the screen that didn't equate to cracks, the set looks to be in perfect physical condition.
