Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 08-19-2017, 07:40 AM   #1
gretter74
City & State: Copenhagen
My Country: Denmark
Default System dead - ATP3 - Altec Lansing Computer Speak System with subwoofer
Model: ATP3
Issue: The system doesn't respond. As in ... totally dead.
The sound of the system was great for my use, so I'll try to fix it.
There's no visual indication of problems on the components. No smells or sound either.
I've measured the transformer and apparently there's a broken primary coil in the transformer. ( Resistance above 1990 khms. )
Do you agree, it's broken?
How do I go about buying a new one?
gretter74 is offline   Reply With Quote
Old 08-21-2017, 01:54 PM   #2
gretter74
My Country: Denmark
Default Re: System dead - ATP3 - Altec Lansing Computer Speak System with subwoofer
I'm sorry for not getting the photo link in the first post. Don't know what happened.
The sticker label says:
TEN PAO Model no.:TG51219F0
Input: AC 230V/50Hz
Output: AC 12.5V/2.5A
So I guess I'll be getting one of those.
Old 08-21-2017, 09:33 PM   #3
ant3202
ant3202's Avatar
City & State: Singapore
My Country: Singapore
Line Voltage: 230V 50Hz
Input: AC 230V/50Hz
some said that if you need to change, consider a good toroidal transformer as a replacement.
and i think there is multiple voltage on the transformer iirc
ant3202 is offline   Reply With Quote
Old 08-22-2017, 03:30 AM   #4
stj
stj's Avatar
City & State: Europe
you still didnt upload any pictures.
Old 08-29-2017, 04:33 AM   #5
gretter74
My Country: Denmark
The purpose of this post is to test if either I'm a fool for forgetting the image or there's something wrong with my image link...
Edit: ok, that didn't work, so my links are broken.. trying again.
That's better.
Old 08-29-2017, 07:26 AM   #6
stj
stj's Avatar
no it's not.
images must be uploaded here because other hosts wont link properly.
you see it because they put a cookie on your browser.
Old 08-29-2017, 02:50 PM   #7
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
Make sure you check the amp and power supply diodes for shorts. Those transformers typically have thermal fuses for UL (or equivalent NRTL in your country) listing.
Don't put a transformer in there w/o a thermal fuse unless you really know what you're doing! The amp PCB may or may not have fuses, need pix to determine this.
Another thing that commonly opens thermal fuses in those transformers is overvoltage on the AC line, such as when the local 416Y/240V network looses the neutral somewhere before the transformer, putting more than the nominal 240V into your service. Light bulbs get really bright.
"pokemon go... to hell!"
EOL it...
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 08-29-2017, 08:11 PM   #8
goontron
5000!
goontron's Avatar
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
^ Yes, Yes they do!
Tomorrow Is Nearly Yesterday And Everyday Is Stupid!
goontron is offline   Reply With Quote
