Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 08-13-2018, 06:49 AM   #1
evilkitty
evilkitty's Avatar
City & State: VA
Line Voltage: 120VAC 60Hz
Default Fixing a pealing PCB contact
I know these happen to be ground pins, so bypassing it would be easy
buy is the proper way to glue them down, if so what kind of glue, supper glue, hypoxy, etc.?
evilkitty is offline   Reply With Quote
Old 08-13-2018, 10:39 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Fixing a pealing PCB contact
with decent epoxy.
Old 08-13-2018, 03:23 PM   #3
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
CircuitWorks CW2500 as used in this video looks good stuff
https://www.youtube.com/watch?v=vx50YtEC2S8
vinceroger69 is offline   Reply With Quote
Old 08-13-2018, 04:11 PM   #4
diif
City & State: Midlands
My Country: England
Yes, it's good stuff, but not cheap.
diif is offline   Reply With Quote
Old 08-13-2018, 06:41 PM   #5
evilkitty
evilkitty's Avatar
City & State: VA
So would JB Weld Kwik or original be ok to use?
https://www.amazon.com/J-B-Weld-8276.../dp/B0006O1ICY
https://www.amazon.com/J-B-Weld-8265.../dp/B0006O1ICE
I have both on hand
i could use some electrical tape to keep it off the other contacts and then clamp (tape would protect pcb from clamp) it and let it sit a day and use some rubbing alcohol to get any tape glue off
or would that just be a bad way to do it?
Old 08-13-2018, 06:49 PM   #6
petehall347
City & State: worcester
My Country: United Kingdom
being edge connectors i would try superglue . should only need pushing onto socket once. whatever you use it needs to be very runny so it is very thin .
