Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 07-20-2018, 09:52 AM   #1
reddemonic
City & State: UK
My Country: UK
Default Wacom Cintiq 13HD Touch Display
power up, but display get static effect and no signal. when i open up i found this ic is burnt.
could be a mosfet that require for HDMI signal to work.
i can see letter "H". multimeter read 0v on all pin. this ic is probably shorted.
no schematic available.
do i need to buy a working one, just to see the ic Markings?
reddemonic is offline   Reply With Quote
Old 07-23-2018, 03:25 AM   #2
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: Wacom Cintiq 13HD Touch Display
Just for the fun of it I looked on EBay for this
These things are not cheep
But I did find some used ones but even with that they are not cheep either
To buy a used one maybe the way to go unless someone on this forum has one and would not mind taking there’s apart to see what the part number is
Or look what that IC chip is next to and maybe you can figure out what it might be
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 08-11-2018, 04:43 AM   #3
reddemonic
City & State: UK
My Country: UK
hi Sam, i've managed to buy a working Wacom Cintiq 13HD display from eBay.
i've taken a photo of this mosfet.
i cant find "C163H" on google. the chip next to it is "24C02WP"
Old 08-11-2018, 05:20 AM   #4
stj
stj's Avatar
City & State: Europe
i dont see any photo's - upload them.
Old 08-11-2018, 05:24 AM   #5
reddemonic
City & State: UK
My Country: UK
they are there, maybe you have imgur.com blocked.
i've uploaded here, thanks
known working board:
Old 08-11-2018, 05:27 AM   #6
reddemonic
City & State: UK
My Country: UK
bad board:
Old 08-11-2018, 05:36 AM   #7
stj
stj's Avatar
well it is probably a reset chip or voltage regulator, and may be from RichTech
Old 08-11-2018, 05:40 AM   #8
reddemonic
City & State: UK
My Country: UK
24C02WP is a eeprom chip, if the chip is bad then i'll need to make a dump from the good working board.
Old 08-11-2018, 05:51 AM   #9
reddemonic
City & State: UK
My Country: UK
very similar to this chip's design
https://www.richtek.com/assets/produ...DS7285A-01.pdf
Old 08-17-2018, 09:55 AM   #10
reddemonic
City & State: UK
My Country: UK
i've found it, if any1 want to know.
https://www.aliexpress.com/item/ESD-...689495708.html
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
