Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 05-02-2018, 11:34 AM   #101
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Default Re: Cyberpower PR1500 won't charge battery
The VIPER has internal charge pump circuit that charge up the 22uF startup/running cap, when the the VDD reach the startup Voltage point to get the VIPER running then the charge pump stops then the VDD get the running Voltage from the AUX winding.
That protection Zener D23 is not needed for the VIPER to run, it is for protection in case the VDD goes up to high, typical Voltage for that Zener is around 22V.
The diode and the 50K resistor and the the cap are for the RCD snubber circuit (R1/D1/C2 in the example circuit as shown in the spec sheet).
From VIPER22 spc sheet page 6/20
Power supply of the control circuits. Also provides a charging current during start up
thanks to a high voltage current source connected to the drain. For this purpose, an
hysteresis comparator monitors the VDD voltage and provides two thresholds:
- VDDon: Voltage value (typically 14.5V) at which the device starts switching and turns
off the start up current source.
- VDDoff: Voltage value (typically 8V) at which the device stops switching and turns on
Old 05-02-2018, 11:55 AM   #102
reberhar
Computer Tech
City & State: Oaxaca, Oaxaca Mexico
My Country: Mexico
Line Voltage: 120VAC 60 Cycles
Hi Bud,
I just measured the aux winding. The D25 is providing 12.5 volts DC. This goes to the optocoupler and then to the Feedback pin. The D23 is connected then to the negative side of the aux winding and then down onto the VDD.
So I am trying to wrap my mind about this. This means that the negative side of the aux winding is providing the power for the SMPS as you call it. Since there is no center tap on the aux winding that means that ground is coming through the SMPS. There should be 12.5 volts on the negative side too, although I read nothing when measuring the aux negative tap on the AC of the VOM. Otherwise how can the SMPS turn on? My reference is on the negative pin of the filter capacitor.
I will read your post again about the zener.
I have repaired lots of digital stuff over the years, analog not so much. Usually though, if I am patient I can get these too.
Thanks,
Roy
reberhar is offline   Reply With Quote
Old 05-02-2018, 12:02 PM   #103
reberhar
Computer Tech
My Country: Mexico
Hi Bud,
Thanks for the help. Any suggestions on which zener? I can read the spec sheets to I guess.
You are a wonderful resource.
God bless you,
Roy
Old 05-02-2018, 02:29 PM   #104
budm
budm's Avatar
This is what I see based on your pictures, see the attached marked picture,
D23 22V ~ 24v 0.5W ZENER should be OK.
The circuit in the spec sheet left out the protection Zener, most of them do not use it to save money.
Old 05-02-2018, 04:43 PM   #105
reberhar
Computer Tech
My Country: Mexico
I ordered some 22 Volt units as per your first suggestion. The 1500 had 24 volt units. 22 should be ok though.
Roy
Old 05-03-2018, 12:28 PM   #106
reberhar
Computer Tech
My Country: Mexico
Default Re: Cyberpower 1350AVR wouldn't charge battery - but does now.
Hi Bud,
Thanks for the annotated graphic of the circuit. It does indeed charge without the zener. I am at 27 volts which seems a little low. I am going to change some diodes and the filter cap in that circuit. If it was a lightening strike those could have been compromised. Checking the with scope shows no ringing so perhaps it is a diode or perhaps it is totally normal. I need to let the batteries finish charging.
Your patience is outstanding and your help has been great. I would shake your hand, but I can't reach the west coast of the US from Oaxaca Mexico.
I hope helping is as rewarding to you as it is to the rest of us.
I do similar work everyday helping Bible Translators with their computers, managing the servers and firewalls and yes fixing hardware. It is exhausting. If you get as tired as I do then may God bless you with rest.
Roy
Old 05-03-2018, 01:16 PM   #107
budm
budm's Avatar
The charging Voltage for your two batteries connected in series should be around 13.75 x 2 = 27.5V so you may be OK, I would connect the batteries to the unit and let them charged up over night, no need to turn on the UPS since the charging circuit is running 24/7 the minutes the UPS is plugged into the AC outlet.
https://www.powerstream.com/SLA.htm
Old 05-03-2018, 03:09 PM   #108
reberhar
Computer Tech
My Country: Mexico
Hi Bud,
Since charging is a current operation it is a little hard to tell. However, I am up to 27.2 so that is a good sign. The batteries are connected and seem like they are warming a little. That is also a good sign. I will let you know how things look tomorrow when they have charged overnight.
Roy
Old 05-03-2018, 03:23 PM   #109
reberhar
Computer Tech
My Country: Mexico
Hi Bud,
So we are not looking at 14.2 x 2 or 28.4 like lead acid batteries in a car. Gel cells want 13.75 times x 2 or 27.5. At this point I am at 27.3. which is pretty good.
Roy
Old 05-04-2018, 09:55 AM   #110
reberhar
Computer Tech
My Country: Mexico
Default Re: Cyberpower 1350AVR won't charge battery
Looks fixed. Battery is at 100%. I have been using batteries from another unit. I have also ordered replacement batteries as the others were bad. I found a 24Volt Zener locally which I will install today.
Old 05-04-2018, 11:12 AM   #111
budm
budm's Avatar
Thanks for the follow-up on the repair.
Old 05-04-2018, 04:38 PM   #112
reberhar
Computer Tech
My Country: Mexico
Old 05-16-2018, 04:48 AM   #113
cyberlander
City & State: Melbourne
My Country: Australia
Originally Posted by jr219 View Post
I can do that. I haven't tested anything further. Forgive me, but I'm more of a software and digital guy...
If you let me know what I would need to test (ie: look for chip x, which should run to cap X and measure the output, etc) I can do it and report back.
thanks,
-jr
Hi Jr219,
Did you ever resolve the issue with your UPS? I have the same board with the same issue. Thanks
cyberlander is offline   Reply With Quote
Old 05-30-2018, 12:19 PM   #114
jr219
City & State: Montverde, FL
Originally Posted by cyberlander View Post
Hi Jr219,
I have not. It's still on the bench. Not sure if I should replace that one cap or not. Considering just purchasing a new one as sad as that is.
jr219 is offline   Reply With Quote
Old 08-15-2018, 12:10 PM   #115
alphatango
City & State: Ontario
My Country: Canada
Just opened up my PR1500LCDRT2U because it wouldn't start up. Battery was voltage was 26V but the charging leads couldn't hold steady voltage on the multimeter. The cause looks like 2x 63V 2200uF leaking caps in the back left corner of the board. I've never done a cap replacement before but I'm going to try!
alphatango is offline   Reply With Quote
Old 08-15-2018, 12:46 PM   #116
budm
budm's Avatar
See post #17 and read the follow-up posts.
Old 09-29-2018, 09:31 PM   #117
okto
City & State: maracaibo. zulia
My Country: venezuela
hello, my name is Frank, BUDM can you help me please... I have right now the same problem. The UPS won't charge the battery... I have a UPS Cyberpower model CP1500AVR... The Battery are New......Dou you have the service manual for this equipment ? Thanks very much for all.
okto is offline   Reply With Quote
Old 09-30-2018, 01:21 AM   #118
budm
budm's Avatar
Is your board the same as in my post #17? If it is then read post #17 and later to know which caps to replace.
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
