Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Thread Tools Display Modes
Old 05-20-2019, 08:24 AM   #1
Fabbrone
City & State: turin
My Country: italy
I'm a: Knowledge Seeker
Default Help HP Z440 workstation
Good morning, the pc only turns on the front led and the fans but not from acoustic signals or other. I have already tried to change the video card to the RAM and the CPU but nothing. Could it be the bios?
Fabbrone is offline   Reply With Quote
Old 05-20-2019, 02:11 PM   #2
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Help HP Z440 workstation
I assume it worked before?
Have you tried a known good power supply?
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 05-21-2019, 01:37 AM   #3
Fabbrone
City & State: turin
My Country: italy
yes I have already tried another power supply but nothing
Old 05-21-2019, 04:08 AM   #4
Agent24
I see dead caps
Agent24's Avatar
Check BIOS battery is not low, if it is, replace the battery and reset BIOS settings with hardware button or jumper?
Old 05-21-2019, 09:50 AM   #5
Fabbrone
City & State: turin
My Country: italy
The battery is ok
what do you mean to reset the BIOS settings with the hardware button or the jumper?
I moved the jumper for the reset but nothing
Old 05-23-2019, 03:34 AM   #6
Fabbrone
City & State: turin
My Country: italy
someone has available source of bios ?
Old 05-23-2019, 05:11 AM   #7
Agent24
I see dead caps
Agent24's Avatar
Yes, that's what I mean. Move the BIOS reset jumper. Make sure you move it back afterwards.
Can you get the BIOS from HP? Typically they don't go bad by themselves though...
Old 05-23-2019, 06:57 AM   #8
SMDFlea
City & State: York
My Country: UK
There`s only a bios update on hp .What is the serial number,to get to the correct support page, and can you post your bios backup .
SMDFlea is offline   Reply With Quote
Old 05-23-2019, 08:44 AM   #9
Fabbrone
City & State: turin
My Country: italy
is this the first time I disassembled this machine, to remove the main one you also need to remove the screws under the heat sink?
Old 05-23-2019, 09:10 AM   #10
SMDFlea
City & State: York
My Country: UK
Service manual http://h10032.www1.hp.com/ctg/Manual/c04823811 .Did you try a bios recovery disk.
Old 05-23-2019, 09:25 AM   #11
Fabbrone
City & State: turin
My Country: italy
Ok removed, here is the original source
Old 05-23-2019, 09:26 AM   #12
Fabbrone
City & State: turin
My Country: italy
no I have not tried with recovery disk
Old 05-23-2019, 10:27 AM   #13
SMDFlea
City & State: York
My Country: UK
Two different bios to try,the bios backup had errors decompiling with Flash Image Toolkit, meaning the ME was corrupt.
Old 05-24-2019, 05:06 PM   #14
SMDFlea
City & State: York
My Country: UK
The 2 bios posted above aren`t working. Here`s 2 new ones to try.
Old 05-25-2019, 09:11 AM   #15
Fabbrone
City & State: turin
My Country: italy
even with this version fans and LEDs light up but nothing is displayed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
