Old 01-17-2022, 01:10 PM   #1
WhiteWolfHellas
City & State: Athens
My Country: Greece
Default Toshiba 32AV933G stuck on stby
Hello, I have this TOSHIBA 32AV933G and it is stuck on standby LED (red). It doesn't turn on and the 12V is missing. Anyone has any experience with these PSUs and what to check? (DPS-140SP A)
WhiteWolfHellas is offline   Reply With Quote
Old 01-17-2022, 03:12 PM   #2
lotas
City & State: Sochi
My Country: russia
Default Re: Toshiba 32AV933G stuck on stby
Maybe the firmware has crashed.
lotas is offline   Reply With Quote
Old 01-17-2022, 03:20 PM   #3
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
Are you getting a change at your PS_on terminal?
dskall is offline   Reply With Quote
Old 01-18-2022, 02:31 AM   #4
WhiteWolfHellas
My Country: Greece
Nope, 0,0V at PS_ON. Any other idea?
Old 01-18-2022, 02:33 AM   #5
WhiteWolfHellas
My Country: Greece
I thought about this too. Do you think the 25Q64 needs programming?
Old 01-18-2022, 02:50 AM   #6
lotas
City & State: Sochi
My Country: russia
What is your motherboard number and panel number?
Old 01-18-2022, 02:53 AM   #7
yokoono
If you don't try you don't know. I think I wrote 993 wrong instead of 933.
yokoono is offline   Reply With Quote
Old 01-18-2022, 03:52 AM   #8
WhiteWolfHellas
My Country: Greece
Panel: LTA320AP05
MB: 32AV933_MAIN BD 11580673-MB00309-60EB40M0KB02P
Old 01-18-2022, 04:01 AM   #9
WhiteWolfHellas
My Country: Greece
I just injected 3,3V with my bench PSU to PS_ON and 12V and 24V appeared, so my PSU is OK. The problem is the main board?
Old 01-18-2022, 04:20 AM   #10
lotas
City & State: Sochi
My Country: russia
Panel: LTA320AP05
Try under your panel.
Old 01-18-2022, 04:55 AM   #11
WhiteWolfHellas
My Country: Greece
I just removed it, programmed it then resoldered it back to the main board, still the same unfortunately.
Old 01-18-2022, 05:09 AM   #12
lotas
City & State: Sochi
My Country: russia
Check all the voltages on the motherboard inductors, maybe there is no voltage or the voltage on them is too low.
Old 01-18-2022, 10:25 AM   #13
dskall
dskall's Avatar
My Country: usa
Check your power on and ir for voltage and change when you press buttons. Try heating up main chip and see if it comes on, BGA problem. 3.3v on pin8 of eeprom. 1.2v for processor core. Voltage at oscillator.
Old 01-18-2022, 10:36 AM   #14
nomoresonys
City & State: midwest
My Country: U.S.
Did you check the solder joints on the powersupply?
(Signature) One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
nomoresonys is offline   Reply With Quote
Old 01-19-2022, 04:57 AM   #15
WhiteWolfHellas
My Country: Greece
I see voltage change when I press buttons on the remote and there are 3,3V on pin 8 of eeprom.
Old 01-19-2022, 04:58 AM   #16
WhiteWolfHellas
My Country: Greece
PSU was checked for cold solder joints, nothing suspicious.
