RCUnlocker
    Re: RCUnlocker
    Originally posted by stars-n-dust View Post
    I have a BIOS file from HP x360 1040 G6 which needs password cleaning. Unlock tools are unable to clean it, anyone can help?
    Did you compare both files after running the unlock tool?
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: RCUnlocker
      Hi. I used the RCUnlocker tool, but still can't unlock the BIOS.
      Attached is the BIOS program for the hp 400 G7 that I exported with the programmer.
      The version is: S71 Ver 01.03.02 03/25/2020
      Can you please clear the corresponding BIOS password.
      Thank you so much!
        Re: RCUnlocker
        Originally posted by final_bad View Post
        Hi. I used the RCUnlocker tool, but still can't unlock the BIOS....
        I don't think so. Attached to the message is the resulting file created by the tool.
          Re: RCUnlocker
          I unlocked an 840 G6 using RCUnlocker, many thanks! After writing unlocked .bin file into BIOS and reset BIOS to factory default I had to make a firmware update to Intel Management Engine because CPU was limited to 0,33GHz and machine was running very slow.
          Off topic: reading messages here i saw many had problems reading correctly WSON BIOS chipsets and I want to share my way. I desolder BIOS chipset from motherboard and put it into clamps as in image. I also have an adapter for WSON but I often got bad results - chipset not rcognized, bad reading. With the clamp I have no such problems.
          all donations are welcome,
            Re: RCUnlocker
            Originally posted by volinakis View Post
            ...I also have an adapter for WSON but I often got bad results - chipset not rcognized, bad reading. With the clamp I have no such problems.
            Well, it depends on what type of adapter you are using for the purpose, I haven't had any problems with mine:
              Re: RCUnlocker
              RCunlocker
              says missing file destination argument
              hp unlocker won't even open, compatibility mode either.
              windows 11 pro 64 bit
              edit I need sleep says drop onto exe lol
              but RC unlocker still won't open
                Re: RCUnlocker
                Wont open means what? There should still be some kind of an error.
                  Re: RCUnlocker
                    Re: RCUnlocker
                    So you did not drag and drop your .bin file to .exe file?
                      Re: RCUnlocker
                      Also i need to unlock bios of this laptop
                      HP Notebook - 17-ca0014ds
                      AMD ryzen CPU, i tested with clean bios from hp it said unlocked
                      once I extract bios from the laptop this software should unlock correctly
                      I'm a newb at EEPROM stuff but I'm learning
                        Re: RCUnlocker
                        correct but rc unlocker gives argument error
                          Re: RCUnlocker
                          What argument error? Give me full error message or a picture of it.
                          By the way, crap like HP Notebook is not supported right now. And they mostly tend to get unlocked using a code generator (insert wrong password or just press enter 3 times to get the code if it is not given straight away).
                            Re: RCUnlocker
                            What argument error? Give me a full error message or a picture of it.
                            ill be back on at 9 am eastern Elitebook unlock needed I'm getting the hang of this now. and is this donation page correct
                              Re: RCUnlocker
                              Still seems like you did not drag and drop your .bin file to that .exe file. Instead you either just tried to open that .exe or you have some other issue like for example naming the .bin file in some idiotic way.
                              Like for example 840G1.locked.bin or 840G1 locked.bin is not a proper way to name a file. 840G1_locked.bin or 840G1locked.bin would be the way to do it.
                                Re: RCUnlocker
                                First of all thank you very much.
                                I used the RCUnlocker tool, which also generated the file provided by your attachment. After I flashed this file into the bios, when I turned it on, it still showed that I needed to enter the BIOS password.
                                I judged that the tool only generates a so-called unlocked file in name, and does not actually remove the BIOS password.
                                Maybe my operation is wrong.
                                  Re: RCUnlocker
                                  No, your judgment is wrong. The tool works as it should.
                                    Re: RCUnlocker
                                    So help us help you by giving more information. What model? Where are your files?
                                      Re: RCUnlocker
                                      I'm doing lots of research and getting better understanding of what is going on.
                                      Hp 840 G3
                                      Need computrace removal.
                                      I was told Ch341a would burn bios chip.
                                      Is there a way I can just replace chip and remove computrace,I only ask because I need to work on my solder skills a little more.
                                      Or would you recommend I use ch341a to read bin file?
                                      I'll do either , but what I'm trying to make sure if I just replace chips no more computrace?
                                        Re: RCUnlocker
                                        Hi there!
                                        I'm trying to "desolder" a Macronix (MXIC) MX25L12873FZNI from a HP 820 G3 motherboard.
                                        Even after applying 30 secs of 500° C from a heat-gun I can't move or remove the IC (plastic around already melting).
                                        Could there be any other fixation like a glue or anything else?
                                        If any - how to get rid of this?
                                          Re: RCUnlocker
                                          Yes, files are different, but after installing the new EC chip, laptop won't power on.
