Thread Tools | Display Modes |
#1 |
City & State: Lisbon
My Country: Portugal
Line Voltage: 230VAC 50Hz
I'm a: Knowledge Seeker
![]() Hello
I have this power source to repair, but don´t know the pinout to get it ON. Somebody can help? Thank you. Dell DPS 1200MB.jpg DELL DPS1200MB.jpg |
#2 |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
![]() Check the voltage on the pins on the left side relative to ground.
One of them should have about 12V with the PSU plugged in. This is likely the 12V Standby (+12Vsb) rail. And if this PSU uses active-low line for the PS-ON signal, then another of those small pins should show about 3-5V on it. If so, connect this pin to ground (via 100-1000 Ohm resistor, just to be safe) and the PSU should turn On. But since I don't have this PSU and I am not 100% familiar with it, I suggest making a diagram to show which pin shows what voltage when the PSU is plugged into the wall. Then post the diagram here. On that note, please use the forum's built-in image attachment function, so images don't get lost over time. |
#3 |
![]() Thank you
I send 2 fotos position down and the voltages on the two sides. Last edited by fpsousa; 01-21-2022 at 04:52 AM.. |
#4 |
![]() another photo side down.
Dell DPS1200MB parte baixo down.jpg |
#5 |
City & State: Sochi
My Country: russia
![]() Photo from the Internet.
#6 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
![]() That's a Delta Products CRPS type power supply (CRPS = Common Redundant Power Supply). Here is a pin-out chart:
![]() Pins B24 and B25 are "NC" on a Delta webpage print-out I have. Pins B19 and B20 are SMB address pins that use 3.3V logic levels. Grounding pin A21 should enable the power supply.
__________________
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** All that is gold does not glitter, Not all those who wander are lost; - J.R.R. Tolkien, The Fellowship of the Ring **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Laughable prediction, https://principia-scientific.com/doc...l-most-people/ ; Fully Vaxxed May 2021; Viva CallSJ "5K" (actually 3.26 miles), 9/19/21, 51:19; ZombieRunner Halloween 10K, 10/31/21, 1:49:30; ZombieRunner Quarry Lakes half marathon, 4:19:07, 12/12/21 |
#7 |
![]() Dell dps 1200mb ON.jpgThank you for the help.
I´ve put a resistor of 220 Ohms betwin these 3 pins and the psu goes ON. Last edited by fpsousa; 01-23-2022 at 06:49 AM.. |
Thread Tools | |
Display Modes | |
