Thread Tools | Display Modes |
#1 |
City & State: Ljubljana
My Country: Slovenia
I'm a: Knowledge Seeker
![]() Hi guys,
My parents have a 2013 LG 55LA6908 which is suffering from increasing in frequency intermittent issues, such as random shutdowns (POWER_OFF_BY_CPU_ABNORMAL), UI freezing, dying HDMI ports, etc... My guess is bad solder joints under the main BGA IC. I was trying to find a new main board for it but I'm unsure of the compatibility between different parts, models/screen sizes and software versions. If someone could help me out with the compatible part numbers it would be very helpful! Product code is 55LA6908-ZB.BEUYLJG with LC550EUG (PF)(F1) LCD panel. Main board PCB is EAX64797003(1.2), sticker has bar code with "WJM33233C101048 / 897785815 / 55LA660S-LGD / EBT62297952" I'm able to copy the EEPROM from the old to the new board, if that helps... Thanks for the help! |
#2 |
City & State: BC
My Country: Canada
![]() Your part number is EBT62297952. The blank PCB is part number EAX64797003 and it may be populated differently for different models. Sometimes a different screen size main board from the same series may be compatible but you need to compare all the connectors closely. Have you tried a factory reset? LA and LN series aren't known for BGA failures but for bad backlights.
Thread Tools | |
Display Modes | |
