Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 06-09-2021, 05:47 PM   #1
ChillingCicada
City & State: Virginia
My Country: United States
I'm a: Knowledge Seeker
Default Vizio VO42L Issues: Need Guidance
We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
I also disconnected every device from the TV, but it didn't have any apparent affect upon the problem whatsoever.
I've just ordered a new power cord, because Vizio claims this could be the problem, but I obviously have my doubts as to whether or not this will solve the issue at hand.
Meanwhile, I've also taken the back off of the TV after unplugging it, and currently have it set aside for further troubleshooting. My biggest question at the moment is what the most likely culprit is, and/or is there anything else I can do right now in order to isolate the issue here?
I've taken photos of the main board and power board, which I've also noted the model numbers of, but I'm hoping that I can be guided in the proper direction before I potentially start ordering a bunch of unnecessary parts.
Thank you.
ChillingCicada is offline   Reply With Quote
Old 06-10-2021, 06:39 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Default Re: Vizio VO42L Issues: Need Guidance
If you could post your photo's of the boards they may help.
__________________
dick_barton is online now   Reply With Quote
Old 06-10-2021, 08:32 PM   #3
ChillingCicada
I've attached some photos of the boards from a few different angles. The only backplate I haven't removed so far is the one covering the board on the far left-hand side of the TV. If anymore details are needed, just let me know. Thanks.
Old 06-11-2021, 06:09 AM   #4
dick_barton
My Country: Wales
The power supply could do with a good dusting. I would check all the solder joints on the underside of the power supply especially around transformer joints. The coils at the output also may also have run hot so I would check the solder joints on them too.
Old 06-11-2021, 10:29 PM   #5
ChillingCicada
I do admit that it had some dust, lol, although I was surprised at how little there was inside the set compared to some other devices I've opened up, especially at a decade plus in age.
I just gave it a dusting as you mentioned, and I took some photos of the underside. Everything looks okay to my eyes, but I'm including another photo so you can take a look.
I also have a video clip of the issue from just now, hopefully this will also prove useful:
https://drive.google.com/file/d/1Iui...ew?usp=sharing
Old 06-12-2021, 04:22 AM   #6
dick_barton
My Country: Wales
J7 link doesn't look so good. Also D604 appears to have some residue around it.
Old 06-12-2021, 08:02 AM   #7
dick_barton
My Country: Wales
It may well be worth reading the comments by Budm on the following page
https://www.badcaps.net/forum/showth...ight=dps-260hp
Old Yesterday, 10:03 PM   #8
ChillingCicada
I really appreciate the advice you've given me.
I ended up replacing the power board since I found a great deal on one, and so far the flickering is completely gone. There remains the slightest buzzing sound, along with some undulation in that sound, at least when I'm listening to the exposed board right there in front of me, but the sound appears to have lessened even more so as I've left the TV turned on for a few minutes. I've attached a video so you can double-check it for me before I reassemble the entire set and place it back on the stand.
I may just be somewhat jumpy of any sounds emanating from the boards given what just occurred, so I'd prefer a second set of ears letting me know if all sounds well.
Thanks.
https://drive.google.com/file/d/1zPc...ew?usp=sharing
Old Today, 03:45 AM   #9
dick_barton
My Country: Wales
If it is a used power supply then I would check the the underside of the board to ensure all the solder joints especially on the larger components are well soldered.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
