Re: Samsung 2493HM power board NO 24v to inverter
See the bottom part of post #5 above again.
Basically, you need to test the main power supply. See if there are voltages on the pins "+5.3V" on connector CN851 and "+24V" on the other connector above it.
To test the power board, you will either need to have it connected to the rest of the monitor OR pull pin "PS_ON" high on connector CN751 (i.e. connect PS_ON to 5V standby). Sometimes, it is beneficial to do both, to see if you get different results.
If we know these voltages above come up, then we will know where to go from there. The PFC booster may refuse to run if the power supply detects a short-circuit or some other abnormal condition on the output. Therefore, I always start troubleshooting from the output side and then move towards the input (high voltage) side. It's also safer this way.
