Re: Daytek F19AH
Okay, it looks like Q102 is a general purpose NPN transistor, PMBS3904. Spec sheet below. Pin 5 of IC101 is basically used to shut down the power supply in case of over temperature. Since a thermistor is not being used here like it is in the pdf schematic, the temperature function is not being used. From the IC101 specs, it looks like pin 5 has to be held at above .65 Volts to prevent power supply shutdown. Once it drops below .62 volts the supply will shutdown. With the monitor on can you measure the voltage of pin 5. If it's going below and above .62V, shut off the monitor and perform a short circuit check on Q102 using the numbering config on the spec sheet and retiredcaps instructions at this link:
https://www.badcaps.net/forum/showth...ng+transistors
I'm off to bed.
I'm off to bed.
