Hello to all, this time i meet a symptom that drive me mad !
I have a macbook air 11" A1370 - Board id 820-3024-B (Core i5 1.6 11 (Mid-2011) that is stuck in a boot system loop (chime loop) this computer start and i hear the chime sound that repeat endlessly with only a white screen.
Sometime (rarely) it chime normally (one time) and i can see the blinking folder (this computer doesn't have a ssd for now) after a certain delay.
I realized that if i unplug the lvds cable i does not have any more chime loop… i test on an external screen with adapter but only white screen with sometime (rarely) the blinking folder !
The keyboard seems to not working, (the caps lock doesn't lit) and all keyboard command doesn't respond (Commande ⌘ + Option + P + R etc…) Only the power button do the job !
At first i was thinking the problem is due to an EFI corruption, So i reprogram the efi chip many time (with different bios file) and the symptom is always the same, no evolution...
Because of the keyboard problem, it was impossible to reset the nvram.
Now i was thinking there was a possible shortcut somewhere, do you have any tips related to this motherboard where to put under my investigation ?
The motherboard is corrosion free, the water damage indicator is intact and the board seems untouched but i don't know the past of this laptop…
Have you ever experienced the same symptoms and successfully repaired the motherboard ?
Thanks in advance for your feedback,
Thomas from France
Thomas from France
