SVI3206D Hybrid IC ( BC POWER MODULE BY SANYO)
    Re: SVI3206D Hybrid IC ( BC POWER MODULE BY SANYO)
    and badcaps.net is the best of internet , i really enjoy this experience since a week soon
      after somes research i can'T finally determine if it can be the case of mosfet or igbt but it look definitively one of them ,, need motivation to takeover this project ,,
      did i can only replace the 60 V rail by 12V rail low amp , just to test it without blowing anything ? , i fear this mini mig solder
        Do you still have those silicons that you removed?
          i have 2 of them , with an atmega168 tester sold on ebay the 2 that was not blown resulted that
          firt one
          second :
          both 2 others was blown and not able to test them
          i have put this project in standby because im temporary overdosed by theses SVi'S history
          ME . SVI
          i really sure that on a good road , the P-jfet is probably the P-MOS , and other is probably the N-MOS , i really hate retarded unidentified electronic parts
          to be continued , For sure
            i have these again yes
              long time not posted on this topic just to remind i have this amplifier again and again in standby mode , my transistor was a setup of darlington welcome smoke please dont delete this topic i will rework this subject soon '' C'est mon défi ''
                i will make other test with somes mosfet ans i will drop down voltage to make it more compatible with my parts maybe this power module will revive some day
                sorry for my poor english im french from quebec
                  I was thinking about this concept recently, it would be excellent to be able to refurbish these STK and SVI IC packages!!!
                  Can you tell me how you opened the modules? Did you use heat to melt the glue? I have had no success trying so far, but I did get one open by cutting into it with a dremel, but that was a bit messy... :P
                    i usually put a small flat head screwdriver at the bottom corner by the pins and pry up on the plastic that works all the time
