SVI3206D Hybrid IC ( BC POWER MODULE BY SANYO)
    Re: SVI3206D Hybrid IC ( BC POWER MODULE BY SANYO)
    this look pretty sweet , but absolutly not sure because i know nothing in audio : i juste fuin love this wathever it is
    2N3055/MJ2955 NPN/PNP Matched Pair Transistors
      hahahaha what if ?? i want a transistor , ok wich package ? , i dont want it in a package , just the transistor pleaze XD ahah
        the original module was 130w, a tip3055 is only about 75w afaik.
        even the 2n3055 in a metal can is only 115w
          so this circuit have 2Xnpn in darlington configuration , and 2 pnp too , i will try to replace that only by 1 pair 1 1/2 X Rated, like tip35C and tip36C and bypas the ''darlington setup and see what it will happen , maybe the amp will be not loud as should maybe it will Explode , but this amp is not destined to be drived at max , and not destined to survive at base it should deliver the tip35/36C capabilities at minimum that is not so bad
          Experiencing time , COTTON SMOOKE
          i have already worked on blowed Su-g70 and su -g90 Amp with same defect ( overheated power module ) after Reflowed Hbrid ic ( to replace slided transistors ,, the amp was able to get audio but not loud as should ( Probably because one of 2 pair of transistor was blowed and amplifier lost his half punch ) ,
            EATING KRAZY GLUE IS BAD FOR HEALTH
              they are not run in parallel, that's a stereo amp.
              you need one NPN and one PNP for each channel.
                oups okay ,yeah i think i know what you mean , need mores wires in this case lol , did you think i can use setup of any matched pairs like 2X 2sd2439 / 2sb1588 i know these are Overrated , 160V , if i run it to 60V insead of 160V, what is chance that is work anything ? a transistor of 160V rating can be run at half Supply ? did it work like that? , using an overrated transistor in a less power supply , it will reduce Heat ? , and risk to Blowing transistor? , or it will simply destroy the power suply by taking too much current ? , sorry i have somes noobs question that pass in my head . but plz dont forget that presently i study hard in experiencing anything that look legit , thanks a lot for your time
                  transistor voltage ratings are only maximum, they will work just fine on lower voltages.
                    magiemagnifimerveilleux
                    in french it represent
                    magique
                    magnifique
                    merveilleux
                    (les 3 en meme temps)
                      just to be clear ?
                      for the npn transistor
                      Collector = power rail positive
                      Base = Signal input ( audio signal)
                      Emitter = Stage output ( audio out)
                      For the pnp transistor connection is
                      Collector = Power Rail negative
                      Base =Stage output (audio out)
                      Emitter = Signal input (audio signal)
                      nothing wrong ?
                          Transistor should be rated at x 2 of what the Voltage it will be exposed to. So you should get the transistor that is rated at >120V.
                            what is your reccomnedation for a +/-60V rail ?
                              he said, 120 or higher.
                              so at 160 your fine.
                                BTW, as far as the Wattage rating, the Transistor will dissipate the most power when the load is at half power.
                                  final schematic , comments? anywone see a FATAL ERROR ? otherwise its time to assembly the whole thing and put 115Von it
                                    dont forget to insulate the transistors from the heatsink so you dont short all the tabs together.
                                      they are allready , they are plastic encapsulation h-30min before my capacitor in an eye
                                        "For the pnp transistor connection is
                                        Emitter = Signal input (audio signal) "
                                        Emitter is the output. Emitter of the NPN and the Emitter of the PNP are electrically connected together to form output pin for driving the speaker.
                                        See figure 4 for basic push-pull output.
                                        http://sound.westhost.com/articles/amp-classes.htm
                                        That is a great site for learning.
