Old 09-12-2018, 06:45 AM   #1
danea
City & State: terrassa,barcelona
My Country: spain
Line Voltage: 230VAC 50Hz
Default Acer 5740 fan spinning stops after short time
Hi!
have a Acer 5740 wich is shutting down when in full load.
I check the temps and reach 100 degress in a matter of seconds,idle stays with 65-70.
Now,the problem i found is that the fan is not working properly,starts for a few second then stop.
Change thermal paste,clear the dust and reset EC.
Obviously since the fan is not working the processor can"t handle the temps.
Thinking update bios but i am afraid that it could shutting down in the process.(also the baterry is dead)
Any ideea how to solve the problem?
Thanks.
danea is offline   Reply With Quote
Old 09-13-2018, 12:08 AM   #2
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
Default Re: Acer 5740 fan spinning stops after short time
first, replace the fan and see if problem persists. Shutting down after how much time? Exact time every time or not??
mcplslg123 is offline   Reply With Quote
Old 09-13-2018, 07:24 AM   #3
danea
My Country: spain
hi and thanks for you response
the laptop is shutting down or freeze when put load to processor,monitoring the temp guess is normal since they arrived at 95-100 degrees.
now,the fan start spinning for 5 seconds when boot then is shutting down.
today i observe that the thermal monitor of the cpu is disable and think that not allowed the motherboard to properly activate the fan status.
searching for ways to enable it since the bios does not have such option.
my guess is i am dealing with a bad processor or motherboard.
reflash bios could help but as i said ,afraid not to have the notebook shutdown during te process. notice that the processor power is spec with 25w( HWMONITOR) wich is wrong since is an 35w processor.
Also found this page: https://www.hwinfo.com/forum/Thread-...-How-to-enable ,wich expose the same problem.
Old 09-14-2018, 12:29 AM   #4
mcplslg123
My Country: india
Either replace the fan first as suggested earlier or bypass fan circuit by doing the following:
01. Remove all wires from fan connector except black(gnd). In other words, only black wire will remain in the fan connector.
02. Now connect the red wire to any 3v source from mb.
03.Discard yellow wire for the time being.
Fan should remain always on with this method.
Try and update result.
Old 09-14-2018, 07:42 AM   #5
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Fan is on 5V, if you connect to 3V it will spin with medium speed.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 09-14-2018, 08:39 AM   #6
mcplslg123
My Country: india
That wont harm as it will be always on. btw, this is just for test purpose.
Old 09-14-2018, 12:47 PM   #7
SMDFlea
Moderator
City & State: York
My Country: UK
On this model its usually the EC bios that gets corrupt,or the KBC dies. Flash the bios and EC with a programmer. The EC is MX25L1005
SMDFlea is offline   Reply With Quote
Old 09-15-2018, 12:05 PM   #8
danea
My Country: spain
well,i could say i solve the problem
First, i was take the risk and flash a mod bios wich has thermal configuracion and many other advanced options enabled.Ventilating the motherboard with a plastic cover it was a succesful flashing despite my fear.
After that the fan had moments when kick on but it was behaving erraticaly.
Then i install notebook fan control with an acer 5738g config. file and that gives me total control of the fan since the bios is not properly control the fan.
I lost my programmer(thinking by a new one)otherwise this BIOS and EC dumps could be very useful.
Thank you all for your advise and your help.
Old 09-15-2018, 12:13 PM   #9
danea
My Country: spain
Many thanks again.
Old 09-17-2018, 02:35 PM   #10
businessmind1988
City & State: ACCRA
My Country: GHANA
i have come across this fault many times and i always measure a different 5v for the Red wire of the fan and it works good
businessmind1988 is offline   Reply With Quote
Old 09-18-2018, 12:14 AM   #11
mcplslg123
My Country: india
exactly that's what i suggested him in the beginning but with 3v to be on safer side.
Old 09-18-2018, 01:30 PM   #12
danea
My Country: spain
Grateful for your advise but not have a solder iron or a programmer.
Notebook fan control works great but only in windows envirroment,anyway believe that reprogramming the bios and ec could be a permanent solution.
imagine if i have to reinstall the OS have to dissasembly the notebook in order to properly ventilate de motherboard and cpu to not shutting down because of high temperatures.
And the red wire solution is also a good workaround.
Thanks.
