problem with svod2
    problem with svod2
    hi all
    i am new user for svo2 programmer
    my problem with programmer with ite io i cannot read the ic
    i try to program ic on mb nm-311a lenovo g50-30
    any one can help me
    Re: problem with svod2
    Originally posted by menshawy View Post
    hi all
    any one can help me
    Are you trying to read original ite chip or have you replaced it??
    If you have replaced it8586, then its a common problem of getting this error-ITE series not detected.
    I have alreday posted a solution for this problem in this forum.
    You need to press power switch once, and then try to read it(Pressing of switch after connecting all connections with programmer and with adapter connected as well). Now read and it will read like a charm.
    This happens only with so called new ITE8586 sio
    Hope, it helps you.
      thanks friend
      i was read your post but when i press power switch the mb switch on then shutdown quickly and program hang i think that coz 5v form usb short with gnd of programer
      i will try connect gnd with another way
      thanks for help
        good friend your method is right the problem in my mb i try with another mb and svod2 working fine .read and write ec file
        thanks for your help
          The programming pins on KB9012 are multi-purpose, on some mainboards they are loaded down by other devices and the programmer can't connect.
          That is why some programmers have breakout board for KB9012 where you desolder it from mainboard and place it on adapter board for programming. It is one extra step and you have to be careful, but on some mainboards it is the only way.
          A working TV? How boring!
