Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 11-14-2019, 09:26 AM   #1
tomodachi
tomodachi's Avatar
City & State: Istanbul
My Country: Turkey
Line Voltage: 220
I'm a: Professional Tech
Default LG Xboom PK5 demo mode..probably
Got 2 pieces of new LG Xboom PK5 bluetooth speakers for really cheap price, thanks to a friend. He told me these are demo products as it says on the box
"Not for sales"
Speaker powered by Type-C USB charger cable but not charging battery, I tore one down and checked the battery and charging circuit inside,all ok.
Capacity remains at %10 and not charging above it to (I guess) keep battery from cycling and wearing effect since designed as a unit to stay on a store shelf for a period of time.
You need to plug charger to make it power on, and once you plug charger you can't turn it off with power button because its totally effectless.
Unit runs at full volume when powered, you need to adjust volume from source since volume up & down buttons not working.
Obviously this unit is on demo mode, does anyone have an idea how to turn it in to normal mode ? any ideas will be appreciated.
tomodachi is offline   Reply With Quote
Old 11-14-2019, 09:39 AM   #2
petehall347
City & State: worcester
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Re: LG Xboom PK5 demo mode..probably
try using the reset hole in the rear panel
https://www.lg.com/in/support/support-product/lg-PK5
petehall347 is offline   Reply With Quote
Old 11-14-2019, 09:42 AM   #3
petehall347
if that fails try this .
Power off at the mains. Then hold power button on the top of the sound bar and the power on at the mains then
release power button and it should be out of demo mode.
Old 11-14-2019, 10:18 AM   #4
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
this didn't work, all that do is restarting
this also didn't work, another thing I forgot to mention is without charger it starts and chimes but battery indicator light glows red and unit turns itself off. With a full battery it does same but with battery indicator green
Old 11-14-2019, 11:27 AM   #5
petehall347
maybe there is a firmware update that might fix it ?
Old 11-14-2019, 11:55 AM   #6
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
if you have the app https://play.google.com/store/apps/d...xboom&hl=en_GB
im sure if you go into settings there is a update section maybe this will update the firmware?
vinceroger69 is offline   Reply With Quote
Old 11-14-2019, 02:26 PM   #7
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
thanks for the suggestion, I did it but still not fixed, maybe I should find a good one and copy the firmware and flash it to mine
Old 11-14-2019, 02:32 PM   #8
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
This speaker can't be hardwired to work as a demo right ?
Old 11-14-2019, 07:34 PM   #9
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Quote:
It's possible.
But it wouldn't make sense to hardwire anything. After all, why do that, when you can just take any production floor model, and program a Demo mode to activate by pressing some buttons in a certain sequence or by selecting from a menu. This is what many other modern electronics (like TVs, for example) do, so I don't see why they would try to hardwire anything.
Old 11-14-2019, 07:47 PM   #10
petehall347
"Not for sales" might be they are broken waiting to be fixed .
Old 11-14-2019, 10:30 PM   #11
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
Quote:
Originally Posted by momaka View Post
It's possible.
So true
I don't think so, the person I got them from said he has loads of these and they all have same issue, said he bought them from a bankrupted company
Old 11-16-2019, 04:11 AM   #12
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
Update :
I discovered that speaker s charging circuit working, on mobile application you can see current capacity, now its %100 percent full, but still don't allow me to use it, it turns itself off when turned on. But when connect charger it turns on its own
Old 11-16-2019, 07:21 AM   #13
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
Any chance to find firmware binary file I can reflash ? any suggestions ? I can reflash the firmware to its motherboard.
Old 12-01-2019, 05:15 PM   #14
momaka
momaka's Avatar
My Country: U.S.A.
Would be interesting to see if that indeed solves the issue.
Hoping that someone sees this and can get a firmware dump here.
When it comes to firmware, I usually throw in the towel - but that's just me: I prefer to stick to hardware issues only.
Old 12-02-2019, 04:14 AM   #15
tomodachi
tomodachi's Avatar
My Country: Turkey
Line Voltage: 220
haha thanks, I m also a hardware guy myself but gadgets nowadays piss me off with their strange firmware issues
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
