Has anyone used this type of Lithium Ion Battery Charger Li-ion Li-Po
    Lithium Ion Battery Charger Li-ion Li-Po 3.6V 3.7V 4.2V 3A
    https://www.ebay.com/itm/Lithium-Ion...53.m2749.l2649
    I have one that is 8.4 volts and it works pretty good it does let you know when it is done charging
    These battery charging switching power supply almost always use the cheapest no brand name capacitors they can find really give me a break
    I bought this charger because I have a lot of batteries that I just bought I want an easy way to fast charge them after I have slow charge them a few times frist and yes I will be using a BSM board on them
    Here is the way I cycle them
    I frist charge them slow
    Second I load them at 1.5 amps unit the BSM board cuts them off
    Keep repeating this until I get the same running time results
    Then put them on a battery charging analyster amperage hour reading
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Has anyone used this type of Lithium Ion Battery Charger Li-ion Li-Po
    Here is the inside of this switching power supply
    The voltage with no load 4.21 with a 860 mill amp 3.98 volts
    The switching power supply will start with a 12 volt 20 watt light bulb hook to it
    Of coarse it had no name brand caps inside of it
    How well would you say this switching power supply is made
    9 PC LCD Monitor
    1 Dell Mother Board
      looks like a generic laptop chager pcb.
      notice the holes for a bigger transformer.
        What is the P/N of the charger controller IC on the cold side, if it is charger controller?
          M358 this is what I can make out
          I am thinking it is a LM358
          9 PC LCD Monitor
          1 Dell Mother Board
